SUPERIUM
Low Postage Member
Nov 29, 2005
171
Buffalo, NY
1Supraholic
69
SoCal
wsharp23;1388751 said:
I was wondering if these rims will fit. They come with 20, and 40, offset. They are 17x8. Would it look better to have a greater offset in the front and less in the back to get them to stick out a little meaner? And what tires would be a good fit?
They are the TSW Snetterton rims.
Thanks in advance
http://cgi.ebay.com/ebaymotors/17-8...ies?hash=item254ff4da3a&_trksid=p4506.c0.m245
it's better to get lower offset in the rears so it's not sunken in. . .
wsharp23
29
Grover Beach, CA
91T breezen';1389137 said:
Am I goimg to be the only one to tell him, that those wheels will not look right on a Supra!?:aigo::3d_frown:
Stay away!...TSW=Junk!:: facepalm ::
Whats would be better? I dont want to spend a ton on rims and they looked pretty good. I dont know much about rim brands
RJS22
Ellicott City, MD
Im a fan of agressive wheel fitments, my setup is as of now planned to be....
18x9 0et 235/??/18
18x10 0et (maybe -5et?) 235/??/18
i kno i will need camber and fender trimming, that it not a problem :) any comments/recomendations?
JPsToyota
231
East-Central, FL
18x9 0et 235/??/18
Sounds like you understand what you are getting yourself into. They are going to stick out of the fenders pretty severely and the tires are too small for the wheels.
Recommendations: Get some wheels that will actually fit the car and then some tires that are big enough for the wheels.
RJS22
Ellicott City, MD
notice i said i will run camber so it wont poke severely, and i perfer to stretch the tires.
rodel
SoCal
May 19, 2005
2,266
SoCal
18x9 0et 235/??/18
Check out my sig. Front and rear fenders are flared out. 10.5+18 rear, with a 15mm spacer (equal to 10.5+3). The 9.5+30 front with a 30mm spacer (equal to 9.5+0)
Fender trimming will not be sufficient. You have to flare out your fenders.
You could run 225/40/18 front and 245/35/18 rear.
chefma70
404
Florida
i have a set of rims that measeure 17x10 with a +35 offset in the rear set and 17x9 with a 29+ offset in the front pair.
i have one question .
Will the rims sink in,sit pretty flush,or sit out a little???????
rodel
SoCal
May 19, 2005
2,266
SoCal
wsharp23;1389946 said:
I looked at an offset calculator online and it said that a 17x8 rim with 20 offset would stick out 28mm farther than the stock 16x7 with 35 offset.
The 17x8+20 will still be sunk it. Why do you wanna go with such a narrow wheel?
rodel
SoCal
May 19, 2005
2,266
SoCal
They'll sit close to flush.
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
i am thinking about 19 by 9.5 in front and 19 by 10.5 in the rear, +25 offset all the way....Other than rolling the fender, what else would be needed to get these bad boys to fit?
1Supraholic
69
SoCal
you'll need to stretch the tires a bit in the rear and you can't go too low or you'll rub. . . i was running 19x9.5 +24 with 235/35/19 and 19x10.5 with 265/35/19 tires and was rubbing if i lowered the tein ss to where i couldn't even fit a finger in between the tire and rear fender. . .
black91turbo
Apr 27, 2006
1,064
Jacksonville, FL
1Supraholic;1391991 said:
you'll need to stretch the tires a bit in the rear and you can go too low or you'll rub. . . i was running 19x9.5 +24 with 235/35/19 and 19x10.5 with 265/35/19 tires and was rubbing if i lowered the tein ss to where i couldn't even fit a finger in between the tire and rear fender. . .
Rub even with a rolled fender? Damn i was kinda hoping i could fit 275 on it.....I want to leave about a finger gap between tire and fender. Would I have to screw around with camber settings to get it to look right like some other guys on here have talked about ? Thanks for your reply!
supraguy@aol
Well-Known Member
Dec 30, 2005
4,259
57
Atlanta
Hey! I finally get to add to the thread!
XXR (Sportmax) 502's in chromium back.
front- 18x8.5- offset 35, 235/40/18
rear- 18x9.5- offset 35, 265/35/18
1Supraholic
69
SoCal
Yeah mine was rolled and pulled a little bit, though you may get away with a little bit of camber, but may still rub. . . :(
