My Coilover Concept
4U2QUIK
1UZFE SWAP DUDE!!!
I'llet let the pictures speak for them selves first ;)
the tube was sweated on first then very very very carefully spot welded in place.
limequat
Dissident
Detroit
4U2QUIK;1417793 said:
the bilsteins don't support tems. These are Toiciko's <sp> Sorry I forgot to mention the best part about this setup.
Cool. How do ensure that you don't blow through with your spot welds? I tried something similar once. Gave up after destroying several shocks and lotsa $$$.
kotu100
1,899
Easton, Ma
*sigh* this is why i miss bein a machinist....
good job, make sure you post up the finished product.
what sleeves are those? what springs are you gonna use with em?
limequat
Dissident
Detroit
Canuckrz;1418183 said:
Very very interesting, but do you think those spot welds will be strong enough taking into account how thin the metal on the shock is?
I'm sure it's fine. Strut perches are built similarly.
4U2QUIK
1UZFE SWAP DUDE!!!
The trick here is keeping heat dissapation in mind in order to make a strong secure weld without overheating or distorting the shock/strut. So I used a piece of tube withe the greatest amout of mass to absorb the heat from this spot type weld. I also used a chamfered hole so that there was good bonding between the tube and the shock at the beginning of the weld, and then dissapate into the sleeve.
They're QA1 sleeves, and I plan on using the stock springs to start with. I'm still working on the perches. I'll post more pics as I go.
Mk3runner;1418061 said:
Thanks! nice to see another norcal member!
exactly. those spot welds have lots of strength, plus it's sweated on. It's not going annywhere.
Personally I'd have extended the tubes almost to the base and do the rosette welds down there away from the pistons working surface in the bores.(assuming single tube shocks)
supra90turbo
shaeff is FTMFW!
32
MA, 01440
pff, for $30 I don't blame you for trying.
I'd love to have a machine shop at my disposal. I'd be doing shit like this all the time! lol
nice crocs btw :momaru:
Turbo Habanero
4,229
Tucson,AZ
There is a bilstein shock and strut that is a OEM replacement for Tems
