Hey everyone. That time has come for me. I have decided against the $4k custom CCWs for now and have opted to go with my original choice, Work Emotion XD-9s in WMB (found a source that can hook me up with said discontinued color). My problem is deciding exactly what sizes/offsets to get, as usual. My suspension setup will be HKS Hipermax 2 coilovers and fender work will be limited to rolling and ever so slightly a little pull (I want to avoid pulling if I can). I will not lower the Supra that much, maybe 1.5 inches at the most. The XD-9s only come in the following sizes:
18x10 +18
18x10 +38
18x9 +20
18x9 +30
18x9 +38
18x9 +43
I would love to do an 18x10 all around setup, but from what I have heard from another member that did this, he said that a spacer is required at the front (basically an offset of mid 25s is needed to clear the knuckles). As such, perhaps a staggered set-up will be more simple to accommodate.
I have researched this topic so much that I think I may have over-researched it and now my mind goes blank when I try to think offsets lol. What I last thought was good was 18x10 +38 rear and 18x9 +30 front. I'm just afraid those offsets will still be sunken. I really want to keep the front and rear the same distance from the edge of the wheel well. Also keep in mind that I do not want to stretch my tires AT ALL. I will be fitting at minimum 275s in the rear and 255s in the front.
What are y'alls thoughts/feedback on this? Thanks for your help and time!!
18x10 +18
18x10 +38
18x9 +20
18x9 +30
18x9 +38
18x9 +43
