spiller
582
Australia/Chicago
if you run a 9+ 15 up front you absolutely will have to roll the fenders and run camber. im running those very same specs with a 245/40 (in 18s which is irrelevant) and its barely do-able...take a peek
you'll have no chance with a 255.
a 10+25 on the rear will need a roll with a 275/35 also, im running 10 +22 (275/35) and here's how it sits
Trini got a Mk3
28
In New Jersey
hey think 18x10 +25 offset in the rear and 18x8.5 +30 offset in front would fit on a mk3 flush. or would a +40 offset be good for the front. also tires are 275/35/18 rear, 235/40/18. supra has eibach lowering springs. wats a good offset for the rear b/c i saw the +22 offset with the same tire size don't do so good. i really not looking to stick of out roll fenders.... b/c now i have 18x9.5 rear and 8.5 in front and it fits good with +35 offset all around but i want to put 18x10 in the back since my gurl is getting my rims so i need no ones..lol
Sam
251
Saskatchewan
But my car sits higher than yours and my suspension doesn't have that much travel. So wouldn't I be safe anyways?
Sam
251
Saskatchewan
Captain;1387237 said:
...here are 17"x10 +12 with 255/40 on the rear. Lowered on Eibach Pro's, no fender rolling, no rubbing, small negative camber.
This is the look I want to go for. This Supra has about the same height as my car. Maybe with the +25 offset and if I use my 255 tires for the rear, it would work out ok. Still need to figure out the front. Perhaps the 17x9 +15 with my 235/45 tires and a fender role would be suffice.
disturbed1
372
perth
picked up a pair of new rims today. 17x9.5 +35. could anyone tell me if they will foul on the control arms, or anything else on the inner guards for that matter. i know a 16x8 +50 mk4 rims wont and my rims have another 5mm Less clearance on the inside so not sure if that will be offset by the larger diameter which i know will help - but not sure if enough
cheers
pics of rims for interests sake
Dutch7m
7m for live
Jun 3, 2007
75
The Netherlands
I found a nice set of Wed's kranze but they have a real low offset:
F 19 x 8.5J offset +5mm
R 19 x 9.5J offset +8mm
Would it fit?
Or will i be better of with looking for a set 10J with a +30 offset?
SupraOfDoom
Starcraft II ^^;;
Milwaukee, WI
I have a problem. Good deal on some wheels locally for sale, but the offset is unknown.
The wheels are 17x9 front, 17x10 rear, with some beefy ass tires on them.
Tire size:
What they look like on a MKIV:
What are the chances of them clearing on a MK3 since I'm not too familiar with how much different the mk4 and mk3's are with offsets?
rodel
SoCal
May 19, 2005
2,266
SoCal
cheers
9.5+35 up front...if your car is low, will require a fender roll.
---------- Post added at 10:49 PM ---------- Previous post was at 10:48 PM ----------
They'll fit.
te72
Classifieds Moderator
6,618
9
WHYoming
rodel;1528886 said:
They'll fit.
So if it fits a Mk4, offset wise, it fits a Mk3? Just for clarification... I've already got a good idea of what I'm doing with the back end of mine ;)
a70Derek
Clean& Simple.
Apr 15, 2007
148
$an Diego
whats the biggest offset i could go on a 10" wheel with a rolled fender?
or could i go 18x10 with +25 offset?
---------- Post added at 08:35 PM ---------- Previous post was at 08:34 PM ----------
what's the biggest offset i could go
rodel
SoCal
May 19, 2005
2,266
SoCal
Generally speaking, yes. If it will fit an MK4, it will fit an MK3.
10"+25 will fit.
What's the lowest offset you could go? It will depend on the wheel width, tire width, camber, and ride height.
Mk3Soup
Proudly Sponsored By SPER
Aug 20, 2005
Queensland, Australia
Hey spiller- so you think that you'd have an extra 20-24mm of inner clearance available? ha... got my eye on something thats 18x10 +21front n18x11 +26rear. should work alright with a little bit of massaging. i hope :) haha
HIDPLANET
89 1JZGTE
Depends on what tire size you are looking to run as well.
I recently installed spacers on my 18x10+30 (front) and 18x10+24 (rear) essentially making them +15 and +14 respectively. Fit is close and visually looks how I want them but the rears are very close since I have a moderate fender roll and the fronts should be rolled more to clear without worry of hitting those annoying tabs.
Tire size is 235/40 and 245/40
SupraJDS
603
I'm installing my version 1 ichiba spacers this week (Comes with spacers and studs).. anyone know how difficult they are to install/ any pointers?
Thanks
HIDPLANET
89 1JZGTE
Very simple to install. I recently installed a set of 4 Project Kics spacers and its as easy as removing your wheels, mounting the spacer, torque it down to spec with the special lug nuts, mount wheel and torque with standard lug nuts. Ive heard Ichiba tend to vibrate so for the first few days pay close attention to any vibrations coming from the wheels.
---------- Post added at 08:12 AM ---------- Previous post was at 08:08 AM ----------
Oh I didnt see that you said Version ONE spacers.
With these, you will have to get your old studs pressed out and the new longer studs pressed in. Once that is done, you just splace the spacer on and then the wheel then torque the lug nuts.
SupraMadness
27
Del Rio
Im gona be going 17x9.5 +15 all around on some 235/45. Not sure if it'll fill my wheel gap tho. Lol. If it dont i should just get coilovers. Haha.
scotty
476
Norway
scottnicholas.net
Hey. Got an offer on some super cheap 19x8 offset 45 rims, how will these fit on my supra? The car is not lowered. Will they bolt on with no mods needed? Got no clue about rims etc so any help is appreciated!
