sparkplug619
2 Supras, 1 Paycheck =[
Sep 28, 2008
285
San Diego California
10? on the website? really? show me please
http://www.xxrwheels.com/sportmax_962.shtml
also, I barely learned how to read tire sizes yesterday so if im making a bad choice then sorry for being a noob.
From a few examples given on the first page I was able to determine a 275 on a 9.5, I asked if it was possible to fit 285's on a 9.5 because I havent seen it done in the 50+ pages I read through this thread. If a 275 is going to cause handling issues then how come there are 4 examples on the first page alone?
projectsupra
旧車スープラ
West Palm Beach, FL
s235.photobucket.com
:dunno:
Fitment will also depend on the tire manufacturer and model, some tires appear a bit wider or narrower for the same given size. Any manufacturer will recommend exactly what size rim that size tire is intended for. I run RT615 and Star Specs on my 9.5" and I wouldn't go wider than 255, both are almost square.
As for others running 275 or 285 on 9.5" I can't say, maybe they like the feeling, don't want to buy new wheels, not my concern.
lukebaumstark
14
inland empire, rancho cucamonga
sparkplug619;1408669 said:
The setup I want is xxr 962's... 18x8.5 in front and 18x9.5 in back
I want the widest tire I can fit on this wheel for the rear so maybe a 275, or 285 if possible, and a 235 in front
is it possible to fit a 285 on the rear for a 18x9.5?
i have that set up,18X8.5 225/40 fronts and 18x9.5 235/40 rears
with 25MM spacers all around making them a 10 offset
theprodigy79
Irish Cream
Mar 5, 2007
221
Centreville, VA
Hey everyone. Haven't posted in a while... Unfortunately I hit a pot hole, blew out a tire and bent one of my Rays so I'm looking into a new set of wheels.
Does anyone know if 19x9 +38 and 19x10 +38 will work for our cars without any rubbing? If so, what tire widths do you recommend?
Thank you very much!
James
87nasupra
Scotty's Garage
Mar 2, 2006
993
Jacksonville, FLORIDA !
If you figured toyota made the TT wheels with a 235-45-17 on a 8" wheel and 255-40-17 on a 9.5" wheel they have a slight stiffer sidewall and stretch just a bit when going on. I deal with rims alot during the day and I hear a 8-9" wheel, depending on vehicle ,from different wheel makers calls for 245-255 w/o alot of stretch. Just my 2 cents
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
SHatty pics but you get the idea...
MB battles 17X9.5 +15 offset... 235 45 17 or maybe 235 40 17, i forgot!!!
Oh yea... 1.5" spacers on all four!!!
R3N5LOW
116
OREEGON
fuck.
please post moaaarr
mb battles are too legit
i think im starting to see mk3's get into the more aggressive offset group
bout time!
jd_kittle05
102
Texas
Anyone know where I can find longer wheel studs at? I am trying to run a wheel spacer but the studs are not long enough. I have already tried 4runner, landcruiser, and Is300 studs and they are all the same length. Also where can I get some cheap 10mm spacers from?
disturbed1
372
perth
new rims arrived in the post today, fresh from japan off yahoo auctions for the pricely sum of $100 . work rezax roar. 17x9 +38 and 17x10 +45.
currently test fitted with racing slicks however these will be my drift rims.. with 20mm spacers
redhot91gt
Grenade Builder
Nov 9, 2008
126
Mesa, AZ
Figured I would ask before I buy some wheels. Im looking into getting some 17x9 wheels with 24mm offset (both front and rear) Will this be a big problem? I will have H&R springs with illumina II's. What size tire should I run for front and back? Didnt see anyone running this setup in this thread(possibly overlooked)
Thanks
-Stu
SUPERIUM
Low Postage Member
Nov 29, 2005
171
Buffalo, NY
Thanks
-Stu
I have the same suspension setup and running 17x9 +35 all around with 255/275/40 tires. 245/40 front and 255/40 rear would be ideal for you. You could pull off a 275 in the rear but you will have to roll ur fenders if you plan on doing any hard launches or jack up one of the front corners you will hit.
JB91389
decisions...decisions...
Jun 22, 2006
698
Ottawa
SUPERIUM;1388862 said:
18 x 8.5 offset +35 with a 245 or 255/40 tire
18 x 9 offset +30 with 275/35
If I wanted somewhat of a stretched tire, what would be a good size?
91T breezen'
ROMNEY/RYAN 2012
Apr 4, 2005
1,149
NOYFB!
SupraMario;1425494 said:
http://nashville.craigslist.org/pts/1413986919.html
Will these fit? and Has anyone heard of A-Tech wheels? They are 18X8/9, just don't know the offset >< Emailed the guy. I think they would look good if they will fit flushly.
BTW Google search for A-tech really doesn't turn up much?
Those are probably either Weds Sa-70's, or MB "Weapon's". Depending on tire size, flush fitment for those sizes would be 5-15mm offset for the 8's, and about, 15 or 20mm for the 9's. I would highly recommend rolled fenders, before any attempt at that aggressive of fitment.
