Wiring Harness Terminals
shaeff
Kurt is FTMFW x2!!!!
9
Around
Try checking with figgie. If anyone knows, I'm willing to bet that he would. He's a wiring nut.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
Figgie, I assume the Sumitomo MT series is equivalent to the majority of our wiring harness? (looking through that catalogue i posted, many of the connectors look like those on our engine harness)
I've found a site that sells quite a few varieties of the sumitomo terminals, although they do not have the male terminals listed for the MT series. I may have to send them off an email... http://www.automotivewiringsystems.com/4-40-products.htm
figgie
Twin Cities, Minnesot-ah
well Summitomo is Japanese so it will not surprise me one bit that they do spply to Honda, Toyota, Mazda etc. Thankfully the Auto industry has gotten thier stuff together with exchanging parts with similiar from competitors.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
Yeah, this site has pretty much every single terminal/connector I was looking for. Nice to see they have the H4 headlight connector as well...as they are no longer available from toyota.
supraguru05
Offical SM Expert: Suspension & Vehicle Dynamic
Dec 16, 2005
737
louisville ky
out of curiosity this is kinda related along these lines, can the factory ecu plugs be re pinned ie the 3 large connectors that feed into the ecu.
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
I would think the ECU connectors are soldered straight onto the PCB inside the ECU so you would probably need to use a soldering iron and pull the old pin out of the board but it shouldn't be too much trouble.
shaeff
9
Around
Be more specific. Depending on how you read your post, you could be talking about either the wiring harness side, or the ECU side.
supraguru05
Dec 16, 2005
737
louisville ky
i appologize i am asking about the wiring harness side. namely due to a botched knock sensor rewire a couple years ago i would love to run fresh wire using the kit i purchased from you a little bit ago, since the place where i spliced into the factory harness a long time ago is really close to the connector leaving me almost no room to work.
Jeff Lange
Administrator
4,918
4
Calgary, Canada
jefflange.ca
Maybe not the exact ones that came on the MK3 aren't, but Toyota still uses H4 bulbs, just get the connector for one of them, maybe?
Jeff
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
Fuck yeah, mailman arrived today...
My crimper and I are going to have some fun!
wow I'm a nerd.
dreamweaver13
29
milford, MI
Adam,
Looks like you bought the 4 terminal MT connector. I was looking to buy the same part, but I couldn't verify if it was interchangeable with the stock connectors.
For example. I need to replace the harness-side connector at the CPS (green 4 terminal). From the pictures, it doesn't look like the MT or HM connectors are interchangeable. If I have to replace both sides of the connector, I may as well buy something more local.
thanks
Jordan
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
dreamweaver13;1272300 said:
Adam,
thanks
Jordan
the connectors themselves are not interchangable, but the pins are exactly the same. You can de-pin and install a new plug pretty easily. I did this for my fuel injectors to avoid chopping up my harness.
edit: I've got 3 old wiring harnesses kicking around and could probably de-pin one of the connectors you are looking for and send it to you...pm me if you want.
