BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
emission;899677 said:
um.... would 18x11 +0 Offset fit 305/40/18 :biglaugh:
Your car going to be in the air. Me and Duane actually calculated that size and tire.. You will need close to +40 on a slammed car with a pull/widebody/over fender.
emission
1.5JZ powered!
Jun 11, 2005
216
Long Beach, CA
Bingo! :naughty: +0 fits fine. no rubbing....
rodel
SoCal
May 19, 2005
2,266
SoCal
11" +40? How much inner clearance are you gonna have, relative to the control arm?
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
Duane, Do you mean step lip as in a 17" wheel using a center from a 16" wheel? the only technical application of that term ive ever heard was from Fikse when they made a step lip 18" wheel using a 17" face. the wheel Looked small due to the lack of diameter on the face. i think that wheel is discontinued also... but i doubt anyone here is looking to buy Fikse wheels, lol.
yes, a +40mm offset on an 11" wide wheel SHOULD clear the suspension. it depends on how much tire you put on it. anything thats not stretched/pulled is likely to rub on the strut. the strut body is really the only thing you have to worry about. if you are rubbing control arms in the rear, youve either got bigger issues than that or have a bad ass suspension system and are reading my thoughts. :evil2:
an 11" wide wheel is not likely to clear up front, if thats what the question about control arm clerarnce was referring to. the only way you could prevent an 11" wide wheel from rubbing up front was to Limit the amount of steer angle, cut down on negative camber and run offset Pillow mounts... which im REALLY wanting to do with my car; 18x12's have fit on a stock body MK3 and i intend to do it again, or come close to it.
Dec 3, 2003
6,653
Canada
Is this a round about way to ask what wheels I'm going to be running? :icon_razz
rodel
SoCal
May 19, 2005
2,266
SoCal
Spill the beans, Duane. Or is this gonna be surprise attack?
rodel
SoCal
May 19, 2005
2,266
SoCal
upgradedsupra;900756 said:
Nope, WRONG again! :icon_razz Don't know what they are still though :biglaugh:
So what did you and BorHor figure out on the wheel sizes and fender pull?
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
Question:
The MkIII always came with equal sized tires all the way around, and a 53/47% (factory) weight distribution... in terms of handling corners (only), would it be better to run equal sized tires/rims all the way around, rather than staggered? I know for a fact larger fronts makes it oversteer like a motherfucker... so would 17x9.5 with a 265/275 on all corners make it more balanced and predictable?
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
lol duane.... i wasnt exactly intending to Ask you specifically what wheels you were goin for. but if you wanna LMK, feel free to PM me or text me if you still have my Cell # lol... with your tastes, i bet they are goinna either be german wheels or spanish wheels :)
