Needboost;1968137 said:
Hvyman. Thats what lug nuts I have. Could you read my other post to see if you can help me out with my rubbing issue?
Should have set the rim on a piece of wood.
That size will not rub. Also the higher positive offset the farther the wheel sits in the fender well.
MK3POWER
13
Miami, Florida, United States
MK3POWER;1967697 said:
i was wondering how a18x8 +15 and 18x9 +10 would fit our cars or would that be too aggressive mind you that driveability is big for me and I don't want to run an aggressive camber the only reason I'm considering those offsets is due to a crazy deal on a set of folk sf challenge I found any help would be greatly appreciated
Can anyone help?
Satan
Tampa
I have 18x8.5 front and 18x9.5 rear (35mm all around). Perfect fitment in my case. Doesn't stick out too far, or too inside. My fitment is flush and no rub, dropped Tokico/Eibach (polyurethane suspension bushings).
I really don't think 10mm offset is usable, but maybe someone else has more to offer...
RPSil13
464
Anaheim, CA
MK3POWER;1969124 said:
Can anyone help?
it would look and prob just require a roll in the rear
i run 18x9.5 +15 all around and have a set of ms1's in 18x9.5 -3 that require a more aggressive roll (slight pull), but they look great
gsxr141
1,158
10
rochester
i need to figure out how to fit a 295-30-18 under the rear fender. i'm thinking 18x10.5, with maybe a +40 offset.
any suggestions?
gsxr141
1,158
10
rochester
i had to roll mine to fit 18x9.5 +25, with a 275-35. i'd like to have more of the wheel under the car if possible, but that would probably mean custom wheels.
If your running springs and shocks you can not run as much inside as it gets close to the shock and spring. Coilovers are much skinnier and you can run more in it.
yhatzee89
Joe Yantz
Aug 31, 2012
985
8
San Antonio, TX
rtrdpenguin;1613719 said:
16x8 -10 F 205/50/R16
16x9 +0 R 225/50/R16
More pictures to come later with 205/55/R16 up front to get rid of the rake and more lowerage once I get the wheels repaired/refinished :)
I know this is a really old post, but how did you like this setup? Were the 16x9s the SHP rims? Any rubbing?
SmithElite12s
68
West Fargo, ND
I'm looking for a fitment about as aggressive as this with 9" wide all around. What offset will get me close to it or at least flush with the fenders and quarters? +25?
Edit: I just happened to be browsing for rims when I notice the ones I want actually only come in a 9.75" width. Will there be clearance issues with them in the front?
MK3POWER
13
I really don't think 10mm offset is usable, but maybe someone thankselse has more to offer...
That offset I agree is more usable but I want some thing that looks aggressive and the wheels I would be getting are discontinued so I can't order an exact spec price is really good as well
Very helpful thanks so the fronts should be fine with a roll right
Needboost
312
danville, virginia
with that being said if im running h&r springs and shocks will i habe problems with a 10 inch wheel in the rear with 265s?
#04
526
Cambridge
I went 17X9 +25 and with a minor fender roll it looks FLUSH when I measure it with a paint stick.... scroll back 15-20 pages....
No you won't. +25 will easily clear. I think around +35 it starts getting close.
With coilovers I think I have another 1-2inchs of space.
rodel
SoCal
May 19, 2005
2,266
SoCal
hvyman;1974841 said:
You could pull the fenders but will prolly chip the paint.
Additionally, body work will be required since pulling will involve deformation of the fender.
