wobssorc
25
Bundaberg
thanks guys. Yes I agree the front could be a +30 with that tyre size i recon.. but it still works great.
nothing with the fenders, only rolled the lip up.
Im on HSD HR Coilovers. Soon to be other gear going in so I can have more front negative camber and tighten it all up.
The Aerokit is some Tracer sideskirts and rearbar. Front is pre 88 conversion nose with a fibre glass 32gtr front glued on.
Had it like this for Years. :)
Always seems to get a look.
wobssorc
25
Bundaberg
for those wondering, I normally roll like this:
Koya Black Driftteks
Front - 17 x 9.5 +18 235/45 tyre @1.75deg neg camber (its nice and flush)
Rear - 17 x 9.5 +18 235/45 tyre (this is sad I know, I am literally going to price some 255/40 or 265/40 tyres now!) so dont hate!
^^^ This is one of the best pics that shows the fitment... its a bit dirty in this image.
P.S. you may have seen these pics before as i have put them up on a thread somewhere.
thanks
sylquebec
167
Quebec
ok. I read almost every page of this thread and check a lot of rolling video on youtube. What i understand is this :
Rolling is to bend in the up the small part of the fender going to the inside? Is that correct? (Sorry, my first language is not english so that not easy with technical terms)
Because what is confusing me is that people talk about a small roll or a big roll. Does a small roll is to put the metal lip i'm talking about at 45degree instead of 90? (90 degree would be completely recrop on the inside). That would sound stupid to not roll it completely if you do it so that's i why i'm confused. I think i may be wrong.
Lets me explain this please.
thanks
Drake69
Enjoyin' mah ride...
Aug 24, 2009
648
Richmond, Virginia, United States
I did some researching and can't find the answers I'm looking for. I picked up a set of Starion wheels in 16x7 and 16x8 (factory offset, I guess...) and have my 225/50r16 Sumitomo's mounted on them. I have the 7's on the front and 8's on the back and they rub (ONLY IN THE BACK SO FAR...) when going into corners, on a dig, and uneven pavement due to the staggering. I am lowered using the Eibach Pros and Tokico Illumina IIs which is not an unusual setup on here, and yet I can't figure out how other people can run these wheels without rubbing. I checked all the local performance tire shops, and they tell me that 225/50r16 is the lowest size I can go on 16x8's. Is that actually true?
Here are pics of my ride as it is now.
rodel
SoCal
May 19, 2005
2,266
SoCal
http://i755.photobucket.com/albums/xx199/Drake1969/My%20Whip/11IMG_4506.jpg[/IMG
[IMG]http://i755.photobucket.com/albums/xx199/Drake1969/My%20Whip/11IMG_4507.jpg[/IMG
[IMG]http://i755.photobucket.com/albums/xx199/Drake1969/My%20Whip/11IMG_4509.jpg[/IMG
[IMG]http://i755.photobucket.com/albums/xx199/Drake1969/My%20Whip/11IMG_4512.jpg[/IMG
[IMG]http://i755.photobucket.com/albums/xx199/Drake1969/My%20Whip/11IMG_4515.jpg[/MG][/QUOTE]
You could go all the way down to 205 on an 8" wheel. The tire will have a slight stretch. No stretch on a 215
Montero22
Ormond Beach, FL
I'm looking to get new rims. I'm going with 19"
The Fronts 19 x 8.5 +35 Tire are 245/35 19"
The Back 19 x 9.5 +25 or +40 Tire are 275/35 19"
Which offset should I go with for the back +25 or +40?
wobssorc
25
Bundaberg
go +25 all round in a 19 x 9.5 dude.
ull still fit those tyres as it looks like ur not running super low or anything
rodama5anthony
430
Bay Area, CA
is there any reason why a wheel marked as being 5x114.3 wouldnt fit on my supra?
picked up some mrr gt1s and they wont go on for some reason current wheels are some unknown honda wheels( they came with the car)
Montero22
Ormond Beach, FL
Ok. I'm going with +25 for the back. The wheels I'm getting are ESM-004 (Silver) from ESM wheels.
Size Front 19 x 8.5 +35 with 245/35 19"
Rear 19 x 9.5 +25 with 275/35 19"
I'm on Intrax springs with Bilstein heights adjustable shocks.
rodama5anthony
430
Bay Area, CA
dammit im hella pissed these mrr gt-1 s arent bolting up.......... there supposedly the right bolt pattern but the holes are more spaced apart then wat the should be. the hub bore is bigger then stock so could that be why the holes are spaced further apart?
lbintab
15
Bay Area 510
Hub bore isn't an issue. Bigger than stock bore is fine...just need hub centric rings. You don't have the right bolt pattern. Probably a 5x120
xzeror
1,356
Miramar, FL
if the bolt holes are not lining up then its not the same bolt pattern.
