suprastupid
177
tx
All these people asking if bla bla size this and bla bla that fits.. do yourself a favor and buy yourself this...
http://www.percyshp.com/WheelRite.html
Thay can be had for around 60$ online just search....
You can experiment with ANY size you want on ANY car you want whenevet you any!! Never ask about fitment again! EVER! Best money I've ever spent on tires that weren't tires! Especially if you're getting an expensive set of wheels n tires...
Sent from my R800x using Tapatalk
Torque
255
In your home
Do you guys think it's posible to fit 275/30/19 on a 19"+25 on the back of my car or do you think I should run something smaller? car is not slammed in the back.
rodel
SoCal
May 19, 2005
2,266
SoCal
If your car is not very low, you could fit up to 19x10+25 w/ 275
Supra_Villan
needs his car done
Nov 10, 2007
662
Wellsville MO
Looking to pick up a set of "front runners" for a drag wheel setup, the only size other than 15's that match my rear are 17 (for the front) which is fine, but they are only 7 inches wide, so what offset would be good on a 17x7 front and be as aggressive as possible with no rub or having to roll?
---------- Post added at 01:55 AM ---------- Previous post was at 01:54 AM ----------
lowered on eibach's btw
rodel
SoCal
May 19, 2005
2,266
SoCal
You'll need wheels with an offset that is in the single digits
craigh310
76
Gardena, California
smallIMGP2800.jpgsmallIMGP2810.jpgsmallIMGP2833.jpgsmallIMGP2834.jpgsmallIMGP2790.jpg
This is the setup I have. I could have gone with 245, and 275, but I kept it conservative. The same for lowering, I could go lower, but I can barely get out of my driveway now.
Tein Flex
Work, VS-XX.
Front, 18 x 8.5/R18, +40, R disk, big brake disk, tire 235/40
Rear, 18 x 9.5/R18, +39, O disk, deep lip disk, tire 265/35
No fender rolling
Bleakvoid
Wide-------------bodied
Oct 7, 2010
222
Fairfield, CA
suprashane;1769418 said:
ok im stupid whats offset?
Offset: Distance from the mounting pad to the centerline of the wheel, in millimeters. Positive means that the mounting pad is outboard from center, and there's more wheel behind the face, negative is inboard with more wheel outside the face.
Mounting pad: The back of the area on the face of the rim that's machined for the wheel studs to pass through.
Centerline: Imaginary line in the center of the rim, directly between the beads that seal the tire against the wheel.
rodel
SoCal
May 19, 2005
2,266
SoCal
Centerline. Outboard. Mounting pad. Bead
Im even more confused now.
eltorodebull
28
SC
18x10 in the back 285 30 18s 25offset
18x8.5 240 40 18 in front 35 offset soon to replaced by 18x11.5 in back and 18x10 up front
wheels are xxr
wobssorc
25
Bundaberg
Test fit from a mates JZA80.
Volk GTC Gold.
Front - 18 x 10 +36 265/35 Tyres
Rear - 18 x 11 +35 295/30 Tyres (awesome for a70s!)
rodel
SoCal
May 19, 2005
2,266
SoCal
Volk GTC Gold.
Front - 18 x 10 +36 265/40 Tyres
http://i461.photobucket.com/albums/qq339/wobssorc/IMG_0760.jpg[/IMG
[IMG]http://i461.photobucket.com/albums/qq339/wobssorc/IMG_0758.jpg[/IMG
[IMG]http://i461.photobucket.com/albums/qq339/wobssorc/IMG_0754.jpg[/IMG
[IMG]http://i461.photobucket.com/albums/qq339/wobssorc/IMG_0753.jpg[/IMG
[IMG]http://i461.photobucket.com/albums/qq339/wobssorc/IMG_0752.jpg[/IG][/QUOTE]
Nice wheels.
Tell us more about the aero kit. Could we see more pics?
Bleakvoid
Oct 7, 2010
222
Fairfield, CA
Volk GTC Gold.
This. Front could use some spacer, but that's golden for most guys that don't drop it balls low, but will still roll a fender. What suspension setup are you on, and what aero kit is that? Looks awesome.
