THMotorsports
Group,
Going to buy some RPF1's for the Supra. Have coilovers installed and fenders already rolled. Done a lot of research on this and just want a final word from you guys. I'm not into a stretched look what so ever. I am about good meaty tire contact patch with performance in mind.
Wheel Type: Enkei RPF1
Front: 18x9.5 +45 with 275/35/18
Rear: 18x10 +38 with 295/35/18
Let me know what you think.
Needboost
312
danville, virginia
im about to get my car aligned i have xxr521 front 18x8.5 +25mm rear 18x10+25mm putting 245/40/18 front an 265/35/18 rear and im lowered on h&r springs. what are the alignment specs most of yall run so that i can let the guy kno at the shop what specs that he should be close to.
xzeror
1,356
Miramar, FL
I have like -3.5 camber except right rear has like -1.8. Toe is good. caster is off a little, but im also pretty low now.
Finally got some wheels.
Less talk, moar pics.
18x10 - xxr 521
255/35
275/35
xzeror
1,356
Miramar, FL
Grandavi;1979890 said:
Now those tires are beefy... lol. No room for wheel liners in that front end : )
The fronts are a little too stretched for my liking. A 265/275 in the front and a 285 in the back would be much better ;)
#04
526
Cambridge
Xzeror, those distance profile shots do nothing to show the fitment...
moar pics, please.... perhaps of flushness/fitment....
xzeror
1,356
Miramar, FL
Going to a local meet tomorrow. Maybe ill get some more.
rodel
SoCal
May 19, 2005
2,266
SoCal
xzeror;1980111 said:
http://i695.photobucket.com/albums/vv316/xzeror/IMAG0969.jpg[/IMG
[IMG]http://i695.photobucket.com/albums/vv316/xzeror/IMAG0961.jpg[/IMG
[IMG]http://i695.photobucket.com/albums/vv316/xzeror/IMAG0960.jpg[/IMG
Going to a local meet tomorrow. Maybe ill get some more.[/QUOTE]
Looks good!
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
xzeror;1980390 said:
Thanks guys. I dropped the front a little too much, gotta raise it up atleast half an inch.
whats the offset on your rims? and theyre 18x10 all around!? i want to run 17x10's with 275 nto1's all around this season so i could give me an idea of where i need to be.
xzeror
1,356
Miramar, FL
+25 all around. The rears can fit a 275 ez. The fronts might rub a little but it can work if you Dont slam it.
Rear it's fine. Front you would have to raise it a bit to not rub the fender. 265/35 push and pull on my fender. Top of the fender is at or a tad above the top of the tire on my car.
But I've seen 285 up front.
Needboost
312
danville, virginia
18x10 - xxr 521
255/35
275/35
what fender mods did you have to do to fit these do your fronts rub and did you get to keep ur fender lining?. im gonna hav to roll my rears but i think all ill have to do to the front is bend the tabs a little.
xzeror
1,356
Miramar, FL
Just had all four fenders rolled. Front only rubs because I'm tucking the tire (too low) I could go wider if I raise it up. I havent had my lining on in forever. Once I raise it I plan on putting it back on. Ill keep you updated on that.
AbsoluteSpeed
735
Edmonton AB
A local guy is looking to run 18x9.5 +12 with 225/40/18's in the front and 18x10.5 +12 with 245/40/18's in the rear.
Will this fit? From looking at other setups I think the front will work with rolled fenders but I'm not sure about the rears. They seem like they are going to stick out at least 1/2".
It might fit. Rears will be close tires wise. Tho it's basically going to make getting traction useless.
