Amar;1293250 said:18x9 +9 & 18x11 +20:icon_evil
Whaddya think:naughty:
19x9.5+24 front 235/35/19
19x10.5+18 rear 265/30/19
HIDPLANET;1289850 said:Another shot taken by someone else at the SoCal Picnic with the coilovers adjusted and sittin nice showing 18x10's all around:
HIDPLANET;1293471 said:11's will be hard to stuff tires in without modification. What tire sizes are you thinking of?
Amar;1293635 said:I was thinking 275's......After looking at Rodel's post with the 19X10.5 +18 in the rear, I don't think I can make 18X11 +20 work without fender pulling, and i don't wanna do that.
rodel;1294000 said:Here's a better perspective:
18x10.5+22 with 275/35
Amar;1294407 said::bowdown:Nice fitment....This is the similar to what I'm looking to accomplish, but you pulled the front and rear fenders, correct?
Warpath;1294544 said:Does anybody know if these will fit? I'm lowered on H&R springs.
Front: 18x9 +20 with 235/40/18
Rear: 18x10 +20 with 245/40/18
Thanks,
Jim
1Supraholic;1294880 said:The fronts will most likely rub specially at full turn and you're fine on the rears.
Warpath;1294943 said:Thank you.
Would using 225/40/18's instead, work better up front with the rubbing issue?
jessetooslow;1295636 said:I have H&R springs, I am running 225/45/17 front 255/40/17 with no rubbing issues whatsoever.
Warpath;1295704 said:Good info. Would running 18's though make a difference with the 1" taller wheel?
queenskid926;1295881 said:ok go my new rims installed,
18 x 9 38mm 245/40/18
18 x 10 42mm 265/35/18
Stock shocks, eibach springs. The camber is w,e the camber is when you lower the car. I did the springs and never went to get it realigned after.
Fits nice and flush, my only issue is running the 35 tire in the rear, The rear tire looks skinnier than the front and i hate that so next set of tires for the rear are going to be 275/40/18. It can fill up the wheel gap a little bit more.
Thats to this thread on allowing to make the proper decisions and picking the proper offsets. Soon i will add some spacers and see exactly how flush they can get without rubbing.
87M-GTE;1299761 said:Quick Q about MKIV n/a wheels compared to the TT's,
Are the offsets on both of these wheels the same? and has anyone used wheel spacers behind either the n/a's or the TTs?
Thanks
-Sam
