Well, I went to the track for some practice last night...
I can't argue with that. Absolutely gorgeous.........and it runs good, well except for that whole driveshaft thing you've got going on.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
Wow, that sucks. Sorry to hear though.
I have the 1-piece steel driveshaft from Jawsgear. I'd recommend them or Shaftmasters (vendor here).
Driz: Craig had come across a bunch of posts I'd made in the past about why the Feramic discs weld them selves to flywheels while he was researching the subject.
He asked if I thought it would be ok to use one as his HP was "moderate" ;)
I said no the rest is history.
suprakid24
Turbo'd
Jan 6, 2007
521
Texas
Thanks bluemkiii and suprarcr89
:icon_bigg
And as for the pm, IJ pretty much said it all. We ordered the feramic full face because we wanted a disk that was streetable, and could hold some power. After reading about it on the HPF website, we ordered it. The next day, I did some research and found out that the Feramic disk and Aluminum fly wheels don't mix well. I pm'd IJ because he seemed like he knew alot about it, and asked him if I would be ok with it only making about 500 horsepower. He said he wouldn't risk it. So then my dad called back to HPF to see what they said about it, and they said that only making 500 hp it wouldn't be a problem, so we stuck with that disk. Then it welded itself.
Big mistake.
Dec 3, 2003
6,653
Canada
Big mistake.
As did mine :nono:
I run the Spec and the drive ability is great. It's designed for both street and track so I say get this! It is a little cash but it's what you would need for launching the car hard.
Also replied to your pm.
Duane
:icon_bigg
Big mistake.
It's not really the rwhp that's the issue it's more our fat pigs and getting them rolling coupled with the slow to release hydraulic clutch.
This is a perfect combination for friction welding.
suprakid24
Turbo'd
Jan 6, 2007
521
Texas
some pics of the clutch and flywheel
Clueless
980
Columbus, Indiana
suprakid24;942445 said:
I thought it was a good upgrade, but I guess I thought wrong because it didn't last. It's gonna be steel now, hopefully it won't do the same thing.
Well, while it's unfortunate that this happened to you...you actually made the rest of us supra owners aware that these aluminum driveshaft aren't for everybody(if anybody).
