Slow66;941461 said:Nice carnage!
"If you ain't breakin' stuff, you ain't tryin' hard enough"
IJ.;941615 said:Driz: Craig had come across a bunch of posts I'd made in the past about why the Feramic discs weld them selves to flywheels while he was researching the subject.
He asked if I thought it would be ok to use one as his HP was "moderate"
I said no the rest is history.
suprakid24;941675 said:So then my dad called back to HPF to see what they said about it, and they said that only making 500 hp it wouldn't be a problem, so we stuck with that disk. Then it welded itself.
Big mistake.
suprakid24;941675 said:Thanks bluemkiii and suprarcr89
:icon_bigg
And as for the pm, IJ pretty much said it all. We ordered the feramic full face because we wanted a disk that was streetable, and could hold some power. After reading about it on the HPF website, we ordered it. The next day, I did some research and found out that the Feramic disk and Aluminum fly wheels don't mix well. I pm'd IJ because he seemed like he knew alot about it, and asked him if I would be ok with it only making about 500 horsepower. He said he wouldn't risk it. So then my dad called back to HPF to see what they said about it, and they said that only making 500 hp it wouldn't be a problem, so we stuck with that disk. Then it welded itself.
Big mistake.
Clueless;942357 said:I thought aluminum was bad materials to use for a driveshaft
suprakid24;942445 said:I thought it was a good upgrade, but I guess I thought wrong because it didn't last. It's gonna be steel now, hopefully it won't do the same thing.
