Ridiculous 1000HP 7M Street MK3 Build
Florida
Set the crank in tonight. About .00175 clearance on all mains using the std Clevite bearings aka NDC. .003" thrust clearance. So far so good ^_^!! Yes, I know....I gotta reposition the block on the engine stand so its weight is centered better.
Aleo24
71
Perth
Just read through your build. Looks like your doing it the right way first time and not cutting corners. I plan on building my spare motor for mine in the middle of the year, so its good to see the sort of work that is required to do it right.
Florida
Yep Im trying my best to do everything as best as anyone could. Dirt is the #1 enemy. I went through like 3 cans of brake cleaner going through the block and crank then blew out the oil passages with compressed air. I found that PRI (performance racing industry) magazines and grassroots have the most wealth of knowledge and im lucky enough to have a friend thats been building engines and following the technology since the 70's...found this article to be really useful for engine building http://grassrootsmotorsports.com/articles/rebuild-it-right/
Florida
The assembly lube I'm using. This stuff is intense...very thick and sticky like honey. Found it at the PRI show
Sent from my SPH-L720 using Tapatalk
Sep 17, 2013
757
San jose
people still use plastic gauge? I like measuring several spots with a micrometer and dial bore gauge. I'm always afraid of that plastic causing a short term dry spot on my crank.
but that assembly lube is good stuff.
Florida
Brake cleaner cleans it off nicely. Some of the best engine builders in the world still use plastigauge. It's probably best to use both micrometer/dial bore gauge and plastigauge so you can cross reference the two numbers but I felt comfortable with just using plastigauge.
Im gonna try the approach of micing the rod journals and rods along with plastigauge just so I can compare the two. I don't expect them to be off by much.
Florida
Not much of an update, but I replaced the oil pump bushing. New one is about .001" tighter.
Also ordered $500 in new toyota bolts. Decided zinc plating 300 bolts and nuts is a nightmare, but I will still be plating a few parts like the oil pump drive gear (using one from a 5M-GE using a spacer sacrificed off from another gear).
Grandavi
2,664
8
Calgary, Alberta, Canada
Is the 5m pump gear an improvement?
I remember reading that the 5m and 7m oil pumps were the same except for the pick up tube. I don't remember reading anything suggesting there was any reason to run 5m over 7m
Florida
5m oil pump gear is a stronger gear. 7m gear is known to fail at high rpm with upgraded valve train. It just needs a spacer so it lines up with the timing belt on the 7m.
Grandavi
2,664
8
There should be a stickie on all the little improvements. Something like "7m best build options"
I'm running stock head and valves so I won't have to worry, but I like building for better if it is indeed better.
1986.5supra_kid;1995840 said:
toyotanos proved this^^^
99 times out of a 100 it's because someone has used something sharp edged to jam a spoke so they can undo it and the mark left has created a stress riser...
SideWinderGX;1995859 said:
Awesome build so far!
If I ever went aftermarket rods I'd jump right to Pauters, but IJ. posted somewhere that they don't have the oil hole on the small end. Is this correct?
It's the Spray hole in the beam that squirts Oil onto the thrust surface of the bore that's missing.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
Oil pump gear does not work I looked into it long ago
in 83 they ran a different gear a stronger one but the cogged belt is diffrent the teeth don't match up but in 84 to 85 they use the same gear as the 6m and 7m
what you have to look out for is this I have scene this more then once
