Questions on differences between 7M-GTE and 7M-GE.
Another MkIII
697
Chicago
I'm trying to find out if all 7M crankshafts are forged. So far I have looked on Supra wiki, and 7MPower and I have not gotten a definitive answer from either. I did find in this thread that at least some are forged, my guess would be the 7M-GTE's for sure. What I'm unsure of is if the 7M-GE uses the same crankshaft, or if it is any different. Also, what kind of power will the forged one support safely?
Also, I have found that there are oil squirters in the 7M-GTE, but not in the 7M-GE (correct me if I'm wrong). What I want to know is if there are any other differences between the blocks?
Thanks in advance for taking the time to read this and reply.
-AM3
MaverickA70
desperate parts beggar
Sep 17, 2007
82
arkansas
the cranks are the same for ge's and gte's. 89+ 7m's have the 7m crank which is heavier but better balanced. pre-89's have the 6m crank, which is lighter but is less balanced. im not sure about them being forged. gte blocks have the oil squirters, ge did not. im pretty sure thats the only difference in the blocks. i believe the 89+ blocks are structurally stronger..
i dont think crank strength is an issue if you have good oil clearances on the journals and everything is in spec.
Another MkIII
697
Chicago
Wait, the 7M has a 6M crank in pre 89's?
-AM3
Benerman
VA Beach
so is there any benefit in putting GE cams into GTE? or just get a staged cam? pardon my newb Questions. gotta start asking somewhere.
shaeff
Kurt is FTMFW x2!!!!
11
Around
If you search that question, you'll find lots of locked threads with the exact same answer. It's not worth the effort, and it only shifts the powerband. You'll choke the motor up top. GTE's have GTE cams for a reason. ;)
Another MkIII
697
Chicago
That somewhere should probably be in your own thread...
-AM3
dumbo
1,913
Albera, Too Far North
GTE blocks have 2 knock sensors, GE's only have 1.
GTE block has a turbo oil drain, GE's do not.
Now I got a couple questions haha,
Are the Post 89 blocks actually stronger?
Are all the cranks(6M & 7M) forged?
Another MkIII
697
Chicago
That pretty much answers all my questions except for how much HP a 7M crank will safely support. Thanks for the input guys, I appreciate it.
-AM3
-AM3
More than you'll ever make....
dumbo;1256407 said:
Good Man IJ:thumbup:Thanks.
So much for my dreams on putting forged internals in my 86.5 when the turbo finally pops SOMETHING.
The block is +2mm just about everywhere, I posted a bunch of direct comparison pics between an 87 and my new 93 blocks.
paradox616
472
Melbourne, Australia
i asked my engine builder weather i should use the 6m crank out of my pre 89 block or the crank out of my 89+ block, he said use the 7m crank as toyota just put more counterweights in for a good reason,
dumbo
1,913
Those are some good pictures IJ. I got another question that kinda goes with this thread.
Do you know why Group 'A' MKIII's used GE blocks /w forged internals? No oil squirters right? Did they use any knock sensors at all?
