I'm looking to see pictures of those of you who aren't using the original shitty philips head screw/bolt for the valve cover gasket. I'm changing mine out this weekend, and from reading other threads about the set up, I can't tell if you still use the rubber grommets or if you just put star washers in between the valve cover and the screw/bolt.
Thanks in advance.
-A1C Garganta
Thanks in advance.
-A1C Garganta
