Intercooler cleaning possible?
Datsrboi
Loud pipes Save Lives
Jul 31, 2007
797
Haltom Texas
I doubt searching for this will yield results so here it goes.
Over time I know oil gets into the intercooler core and builds up.. How in the world do we clean all that stuff out? Would spraying engine degrease into the intercooler then packing it with pressure water do the job?
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
I'm not sure it would be easy to do on the car, but here's what I did:
Removed IC from car and cleaned it out with gasoline by filling it up, letting it sit overnight, drain, repeat, then flush with plenty of water allow to completely dry. A butt-ton of crap came out on the first flush, and it was nearly clean on the second.
While it's out, you can straighten the fins and give it a bit of black paint to clean it up. Removal reinstallation's a minor PITA, but not too bad overall.
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Gas would be the cheapest way to go as it takes quite a bit of cleaner to get the job done. 1 gallon should serve well. Half a gallon, cap off both ends, shake that bitch up bunches, empty. Repeat, let sit if you want on the second run for a good deep soaking. ;)
KMinAF
Old Man
Sep 15, 2006
291
American Fork, UT
One of lifes embarassing moments,
The car had been sitting for a while with the engine out and critters had shown some interest in habitating the engine compartment so when I was ready to re-install the engine I thought it would be a good idea to make sure there were no nests in the IC. I hooked the shop vac up then inadvertantly proceded to suck the rag that I had used to block off the other end as far into the IC as it could possibly go. It took almost 2 hours to fish the stupid thing back out.
DL.
Fast
Sep 12, 2005
SE Wisconsin
Any idea on how fast that builds back up in there? Anyone tried cleaning one out after having it on for some miles like 10,000 20,000 or ???
silvergsx623
WIPLSH & HWY KNG
Oct 16, 2005
498
Alabama
I use gas to clean my intercoolers out and straighten the fins, at least once a year. It just makes me feel better keeping everything clean.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
How bad this is will depend on how much blowby your engine has. An engine in good shape will have virtually no oil in the IC. And a catch can will help. An engine in poor shape will fill the IC with oil quickly.
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
It looks like I would have to remove my Bomex bumper to remove and clean my IC. Instead, I was thinking of rigging up a bucket of hot water and Castrol super clean(degreaser) and flushing/cycling it through with a sump pump I have; then rinse, & blow dry overnight. Should work, right?
Wayne G.
87Turbo 5sp Targa
Apr 19, 2005
213
Gainesville,Ga.
Poodles;722947 said:
I used simple green, but that's just me...
I would have used gas if it wasn't really hot at the time (evaporates fast)
Ditto on the Simple Green. Then flushed with water and dried with shop vac.
worked great----
Doward
4,245
Alachua, FL
Million ways to skin a cat.
Personally, I'm gas x 4 at this point, then rinse thoroughly with water + blow it dry with the shop vac.
