Hot weather driving
mjsn1
284
Qatif
Hey guys.
scene its the summer I just want to know what is the hottest weather you drove your car in? And did it heat up. I tried everything with my car, a 3'' radiator, a big fan and it still not drivable in the summer. is it my car or is it just the climate.
gats
Rebuilding... Slowly!
Mar 3, 2009
182
Sydney, NSW
I think you may have some other issues if you can't keep it cool in summer.
When I lived in Australia, I often use to drive in +42 deg C (+107 F) temps with a stock radiator and fans and did not have any issues...
mjsn1
284
Qatif
Is your car a N/A or a turbo?
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
What kind of gauge are you using? If it is an aftermarket gauge you may think it is overheating when it really is not (trust me I fretted over that until I realized).
shaeff
Kurt is FTMFW x2!!!!
11
Around
Details on cooling system? Any leaks? Disappearing coolant? Fan clutch in proper working order? 10 blade fan? A/C fans working? Properly burped system? Thermostat good? How's the radiator cap? Coolant mixture?
Even a pinhole in the system can cause issues.
te72
Classifieds Moderator
6,622
9
WHYoming
I used to daily mine in the east Phoenix area, where typical summer temps see upwards and occasionally beyond 120° F... no major issues, other than a sweaty driver. :)
mjsn1
284
Qatif
I come from Saudi Arabia so your weather is nothing compared to mine i drove my car in 48 to 50 degree it doesn't heat up when the RPM is below 2500 but as soon as i take it to 3000 the gauge (stoc) goes up, maybe i should change the thermostat, and instead of a single V8 mustang big fan i should put double fans.
---------- Post added at 11:57 PM ---------- Previous post was at 11:52 PM ----------
connor.stephens;1717469 said:
I've drove mine (7mge) in 100 degrees+ many times and the temp guage doesnt even budge even when climbing hills and its all stock
there is a big difference between a turbo and a N/A engine, my car was a 2jzge i had no problems with heat, but now with a 1jzgte the only time i can step on the gas is in winter.
---------- Post added June 1st, 2011 at 12:01 AM ---------- Previous post was May 31st, 2011 at 11:57 PM ----------
the problem that i realized is that im not losing any coolant, with this heat i should be filling it up every two to three days
te72
6,622
9
WHYoming
50°C = 122°F, so that's definitely hot. I will say this, driving in Arizona and Vegas, when the weather is that hot, I would see average coolant temps of around 215-220F (~100-105 C), but that was with a rather weak fan. I would suggest trying to fit a fan setup that can flow over 4000cfm if possible.
mkIIIman089
Ohio
The car should easily be able to drive in 120* heat in stock form (radiator, fan(s), ducting/panels).
Yours is either about to blow or your super cooling upgrades are not set up at all correctly. If you're running a stock temp thermostat, I highly recommend going back to a new stock fan clutch and turbo fan; it will more efficiently flow vastly more air when needed than any electric will.
Drove my 7m in vegas all day long with temps past 110*F with the a/c on. Didnt like the freeway with the a/c tho.
You either have some cloggage or a bhg or some engine issues causing it to run hot. How old is the coolant?
Ditto, got mine to a point where I could cruise around in traffic with the AC on and not have an issue.
mjsn1
284
Qatif
I dont remember, but its old, i didnt change it because it doesn't lose coolant.
Hey IJ. where did you get that?
It's a Davies Craig EWP 110, just bought it at the parts store.
7M's barely move water at idle then cavitate their brains out above 8000 so this killed 2 birds with one stone.
