High compression high RPM 7M-GE build
Florida
I sent a PM about the retention plate. I need that in my engine.
andrew_mx83
100
Melbourne
Ok i went to the bearing shop this morning and cleared out their remaining Koyo stock of the thrust bearings (4 more sets) and CNC'd up 4 more plates. They arent quite finished yet, precision tolerances for bearing fits and oil clearances = slow work
pm replied.
Grandavi;1997814 said:
YOu should "pull your finger out" and make a group buy of this with about 20 sets... lol.
Are you going to vent the cover?
lol, this must be an aussie expression "pull your finger out of your arse and get to work"
no venting on the cam covers, PCV will be taken care of via the breather fitting on the block, going to a separate oil header tank/catch can
edit -yes i will make a batch of the cam covers, probably after i get my engine done and running though. i want to be 100% sure they dont leak and the PCV system works as expected first. hopefully this is only a couple of weeks off.... where's my damn pistons??? :/
Aleo24
71
Perth
This is INSANE. Excellent work and excellent finish to each and every component. Not sure if i read it but are you hand finishing the port sections your cnc cant reach?
Those cam covers are mint!
andrew_mx83
100
Melbourne
Its starting to look a bit less like a bare block now. Replacement pistons should be here this week, ring gaps and rod clearances are already set so they should basically go straight in. Still gotta drill or groove the rods for pin and bore oiling (leaning more towards drilling now)
roller bearing installed for rear of aux shaft which blocks off the oil feed to the original plain bearing and saves a bit more flow for the mains
aux shaft modified to suit and assembled with new retention plate
installed, front ready to go together
front and rear covers on, all seals installed
new genuine water pump
new design of engine mounts has a rubber bush instead of poly so are nice and soft like OEM to try and mask the lumpy idle i will probably get from the cams.
Backlash2032
1,823
Nebraska
IJ.;1998729 said:
Did you machine off the fuel pump cam from the AUX Shaft?
Looks like it.. Also I think the post 89 oil pump drive shaft doesn't have the fuel pump cam. Could be wrong though, seems like i built my motor forever ago lol
andrew_mx83
100
Melbourne
All the aux shafts ive seen have a blank round section at the back which could be/used to be turned into the fuel pump lobe, back in the day.
And the round section at the front was turned into a dizzy drive gear i believe
andrew_mx83
100
Melbourne
Timmy belt finally turned up today so i got the front of motor all assembled. Shame im keeping a/c as the tensioner and bracket really un-pretty the engine :(
A better view of the 36-1 crank trigger for my waste spark ignition setup
Also cut and shut the water pipe to suit the LPG converter's new location on the intake side of the engine (the converter needs hot water to, y'know, convert the LPG liquid into vapour). will have to make up some sort of bracket to mount the converter once the head goes on and i can dummy everything up to check clearance.
Slowly running out of things to do on the short motor. have to machine up the oil pump outlet, fabricate (ew) a front sump pickup, baffle the sump and drop the pistons in when they finally arrive.
Then assemble the head, finish the intake manifold and a million other little jobs...
andrew_mx83
100
Melbourne
IJ.;1998761 said:
Mine had the fuel pump lobe offset, I turned it off just cos ;)
yeah i went full retard on an aux shaft years ago but have never been game enough to actually run it in an engine. inside the rear bearing journal is hollowed out as well. weighs a fair bit less than standard :)
Don't think you'd have an issue using that shaft, I had to take mine down quite a bit as it was tapping the Pauter Con Rods I was using...
Can't remember the end diameter I used but it was a good deal thinner than stock..
