Furious But Lazy 7M owner who gave Up.
ThunderZTA
Twitch
Apr 17, 2012
75
Texas
Turbo Habanero;1881793 said:
Thanks for the offer bud but that's not big enough
Albert it going to take my T67 t3 turbo and swap a T4 .70 AR exhaust housing on it today for me,
Oh ok, just figured i'd offer in case you wanted to stick all T4 stuff :)
i love this thread, looking forward to reading more soon!!! I will be starting my build thread soon as well
Turbo Habanero
4,229
Tucson,AZ
1986.5supra_kid;1881994 said:
awesome thread!
so that adapter your using is this the same one?
im putting a hx35 on a 2jzge and it just so happens its a divided t3. and my manifold is a divided t4
http://www.ebay.com/itm/T3-divided-...Parts_Accessories&hash=item1e651293ca&vxp=mtr
Turbo Habanero
4,229
Tucson,AZ
1986.5supra_kid;1882240 said:
can you explain what has been done to the adapter?
Very simple
the two head bolts on the bottom - we had to drill out the threads on the manifold then screw down the bolts to the flange
the two head bolts on top - we had to drill the threads out of the flange and open it up just enough to where the head bolt would sit flush in the flange (so just the length of the head on the bolt) and then screw them down using the maniold threads
Turbo Habanero
4,229
Tucson,AZ
So i'm confused on sizes i need
The three lines are
(Feed) Pump to Res (-6an on the tank)There is this but it says its for -8an so would i just get a braided line that's -8 on one side and -6 on the other? I really no nothing about this stuff. http://store.driftmotion.com/static/i-jzpsfeedadapter-8.php
(Pressure)Pump to Rack (I have this one from DM)
(Return)Rack to Resvior (-10an on the tank) I'm assuming i need the 17x1.5 fitting and again just run a braided line from the -6an to the -10an
http://store.driftmotion.com/static/i-toyotapsrackreturnfitting.php
http://store.driftmotion.com/static/i-16mmx15toan-6fitting.php
