ForcedTorque's 3E5 has Arrived!!!!!
UkiSash
no mor sup :(
Jul 12, 2005
159
Weth CT
thats clean as hell!!!!
apart from the corroded thermostat housing, ABS, and the fans :D
EDIT: and rusted radiator mounts !!!! :( lol
ForcedTorque
Join the 92 Owners Group
6,099
SHhhhhhhhhhh.................You are spilling some of the future Jdub plans. The fan will be cleaned whenever I stop putting greasy hands in there, and a brand new fan shroud will be going on it, or whatever radiator I end up with.
ForcedTorque said:
I'm gonna try again tonight to do a little more on my springs, and have that finished before I get my time off.
UPDATE********1 more spring out of the way. Only one more remains and it should be knocked out tomorrow night. Now I have a front and rear on on the driver's side, and I believe I am going to like the stance of 4 rear struts. As of now, I have about 1 to 1 1/2 inces of lift over the cut spring on the other side. I won't know for sure until a couple days after that last one goes on, but it looks like it will keep pretty close to the same stance as it had on the cut springs, just at a little safer heighth. I like the front slightly lower than the back, and it seems that it will stay that way.
Scott, if you've got three of the four springs finished, then that should be fine. It's not like it's running on two stock springs............you've got three of them replaced. Are you tring to replace all four of them and make the rest of us look bad? You sir are four the loose..................:rolleyes:
UkiSash
no mor sup :(
Jul 12, 2005
159
Weth CT
ForcedTorque said:
I know Jay, I should have finished it all tonight. But I have to stay quiet for the old folks........including myself.
You are forgiven... (although i worked on mine till the wee hours in the morning on my first supra) But seeing as its very difficult to do, and old age ahem, and 1 is better than none :sarcasm:
you know when i first subscribed to this thread i tired reading everything from post one.. It was too difficult. :( i gave up and looked at pretty pictures.
ForcedTorque
6,099
Well Noah, I was just noticing that I just keep knocking off projects that I once was scared of. It's embarrasing to admit that, but it makes me proud as well. I have been counting on your help on my Walbro and 12V mod. I want the help, but I also want the experience too. But, I want it right the first time when fooling with the tak, so the help would be welcome. The problem right now, is I don't know when I'm gonna be able to tackle that project. It will be very soon though, I'll call you.
noah89t
get naked & boost a supra
tackling the projects is just in your mind as far a difficulty. that's cool that you are getting them done. george never pulled or installed the struts and springs on his car and in two weekends we pulled suspension off three supras and installed on two. on the third one he wanted to tackle it himself while i watched.
i never pulled a subframe from a mkiii, but tuesday i pulled the rear one in about half an hour.
jugodegolf
Phoenix,AZ, United States
:boink:
I have really really poor neighbors that depend on my supra for groceries and drugs. I pay them to help me or I pay them to do it for me, either way, they come up here wanting money and instead of giving it to them, I make them work on the supra. Changing my plugs is so easy on a 1j and I could do it in about fifteen minutes, but I would rather pay Ricky or Tim ten dollars and have them do it. They do mechanicing for a living and there's nothing they don't know how to do so it helps me out also.
ForcedTorque
6,099
I've got good news, and I've got BAD news.
Today, I finished up swapping my springs. This last one was the easiest one on the car, and ironically the one I was scared of most. I guess a little experience paid off on that one.
After getting that finished, I set out to at least find my coolant leak. I started by refilling the radiator, then squezzed the upper radiator hose to provide a little movement. Right away I found that I was leaking from the water ling on the turbo. I replaced that hose with a good piece of extra fuel line hose for extra protection. I repeated the hose squeeze to see if it was for sure fixed. That's when I found another leak. It was the hose on the driver's side of the motor running into the fire wall. I tried and tried to fix that hose with nothing helping. I pulled the hose off to find that the copper/brass line was split pretty nastily. It is my belief that I will be pulling the dash apart to fix that. THIS CAR HAS BEEN A NIGHTMARE!
Here's a picture of the good. I kinda like my new stance, but it's a little hard getting used to it not being on the ground. Here it is...........4 rear struts for the world to see. I took the picture a little dark, and the lightening has bleached my faded red paint to worse than it already is, and I should have closed the hood.
gtsfirefighter
SM Expert on White trash
Sep 26, 2006
2,966
DFW
ForcedTorque said:
Damn Ken.......You remind me of an Olympic hurdler! It doesn't matter what these cars throw at you, you stay focused. I wish I could help you.
The above quote is from my build thread. It goes both ways. I'm now passing the baton back to you for now. I'll catch you on the next lap.
n2fishin69
Work-a-holic
Jan 25, 2006
61
Way down South, in Dixie
Scott,
You will be pulling the dash out for that. If you need help let me know, I have become an expert at pulling dashboards out. You could also bypass the heatercore and worry about fixing it later.
Jim
