Oh jeez, don't let your spirits get down!  The car is practically done!  You just need to work out all of the little bugs!
[/motivational tone]
johnathan1 said:The car is practically done! You just need to work out all of the little bugs!
	IJ. said:Boso: Is ALL that smoke from the wire??? :aigo:
BosoMKII said:Most of the smoke came from the switch! The wire was melting the insulation, but it was the switch its self that nearly went up!
Bigaaron: that photo is priceless! + rep for you!!
So I learned the hard way that a 25 amp switch is not enough. Better luck next time![]()
HellsLegion said:The switch was for the fuel pump.
We wired the pump straight to the battery and the wires stayed cool. So basically the switch melted.
