BosoMKII's project! 56k cut your head off
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
LOOOOOOOL
Poooor Corona.
Had fun Matt! Thanks for letting me drive the s14. I want it
BosoMKII
497
NorCal
YESSSSS
Those pictures FRELLING RULE!!!
johnathan1 said:
The car is practically done! You just need to work out all of the little bugs!
Thanks Johnathan. Tonight, if everything had gone well, would have made it look like I know what I am doing :p no the secret is out. I am a shadetree! hahah
BosoMKII
497
NorCal
IJ. said:
Boso: Is ALL that smoke from the wire??? :aigo:
Most of the smoke came from the switch! The wire was melting the insulation, but it was the switch its self that nearly went up!
Bigaaron: that photo is priceless! + rep for you!!
So I learned the hard way that a 25 amp switch is not enough. Better luck next time :p
bigaaron
4,692
Pomona, CA
www.driftmotion.com
25 amp is not enough for what? The real lesson is everything needs to be fused correctly to avoid electrical fires. :biglaugh:
bigaaron
4,692
Pomona, CA
www.driftmotion.com
HellsLegion said:
The switch was for the fuel pump.
We wired the pump straight to the battery and the wires stayed cool. So basically the switch melted.
Huh? The fuel pump is max about 10 amps, you probably had +12v and ground going to the contacts on the switch and when you flipped it on it shorted the battery directly to ground through the switch. There's no way a fuel pump melted the switch like that.
