AR5 Trans Take Two: The Solstice Solution
Spaniard
524
La pearla PR
I gave Mallet conversions a call today, twice. Apparently with their V8 Solstice that have no problems with that transmission what so ever! They told me that have a customer that has a supercharged V8 in his Solstice and his OEM Solstice transmission is holding up like a charm. Now, we all know that the hp doesn't kill our transmissions, it is the torque that does. But I'm sure these guys are beating the crap out of these tranny's, wouldn't you think? I say it is a safe bet that it is a good transmission. But I am looking forward to seeing someone in the Supra world to put it to the test!
Spaniard
524
La pearla PR
I called Pontiac today and they quoted me at $1600 for a brand new Solstice transmission, then I asked, "Is that your best price?" He then asked me what I was using it for? Told him about our swap and then said $1300 is my best. haha.
limequat
Dissident
Detroit
Yeah, $1300 for a brand new trans is not a bad deal at all.
Thanks for checking with Mallet. I think we can lay the capacity concerns to rest!
Isphius
Supra-less :(
May 30, 2006
359
long branch
so what would the overall difference be if you went with a colorado trans? would that have eliminated the need for the chevy driveshaft yoke? I would imagine that might come with some different gear ratios as well. And If i get this right...the solstice uses ecotec motors...does that mean i could put a 7m in my cobalt(fictionally) and the bellhousing would bolt up? Or you could also put a toyota motor into a few different gm vehicles?
Greg55_99
55
MA
MA5 - 3.753 2.26 1.37 1.00 0.729 (Colorado/Canyon/Hummer H3)
MA5 - 3.753 2.26 1.51 1.00 0.729 (Solstice/Sky - 2007 and up)
No, you could not put a 7M into your FWD Cobalt... but... with the Solstice Ecotec bellhousing, you COULD put an Ecotec into your Supra. You could also put a 7M into a Canyon/Colorado/Hummer H3/Solstice/Sky with the proper bellhousing.
Greg
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Greg
or put a 1JZ or 2JZ into a sky right ? wow the worlds first 2JZ in a sky with the 1jz bell housing of course.
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
That would be even better than the 2JZS2K I think... The tranny lines up like it should... and you don't hear people bitch about throwing off the balance of the S2K. Win-win.
Greg55_99
55
MA
LOL! Good idea... but it probably wouldn't fit...:biglaugh:
Greg
Isphius
Supra-less :(
May 30, 2006
359
long branch
Well, thats why I said fictionally. I know the 7m isnt actually going to fit into my cobalt. But this does open a lot of doors to some unique engine/chassis combos without having to do all that much work. Next question...how can we put the 2jzgte in a 4wd truck? sounds stupid, but there is your cheap skyline ripoff.
Spaniard
524
La pearla PR
There was a guy who made the 4WD in a 4Runner work with a 7M, it was a while back. But with the right amount of money, anything is possible.
slidebabyslide
Starting FRESH !!!!
Dec 17, 2006
662
salinas,california
Yea he went to silv04 or 05. I have the video in my moms house. I think you can find it in youtube.
Greg55_99
55
MA
T34418L3ONE said:
so does that mean there is an easy way to bolt an lsx to a r145?
Well.. yeah...
Method 1. Advance Adapters makes a custom bellhousing to mate the Jeep AX15 to a Chevy V8 pattern. It also works (minus the clutch disk) with the R154:
https://eshop.advanceadapters.com/c...15-transmission-adapter-kit-712567-712567.htm
Method 2. Novak Enterprises makes an adapter plate to mate the Jeep AX15 to a GM pattern bellhousing. As before, it bolts to an R154 and then to any Chevy V8 bell.
http://www.novak-adapt.com/catalog/kit_gmax15.htm
The Advance Adapters bells show up on Ebay from time to time.
Greg
is that the Mallett Solstice?
that thing is beyond insain... no use for first or second...
yes, R154 in a 4WD truck is quite possible, it's changing the rear hosuing of the tranny with the 4WD one and bolting it up mostly... after that you can but pretty much anything you want mated to the R154...
Isphius
Supra-less :(
May 30, 2006
359
long branch
so...now we can put an ls1 or small block into a supra with the stock trans or a solstice trans? Im doing it!! I wonder how long the r154 would last with a v8 beating it up, much rougher output than a nice smooth straight 6 turbo. But yes now im def building a v8 supra
