iDriftYou
SoCal/805
hey guys, I was wondering if this setup will cause any issues with rolled and pulled fenders:
18x9 +35 up front (245's)
18x10.5 +20 in the rear(275/285's)
I really want to get 18x10.5 +20 all around, but I don't know if the front fenders will allow me to. :/
1Supraholic
69
SoCal
You will encounter rubbing up front with 18x10.5 +20 upfront with those tire sizes and only a roll, you'd need a pretty good pull, run stretched tires and camber to 18x10.5 +20 upfront.... here was my set-up a few years back: 19x9.5 +23 235/35/19 & 19x10.5 +24 265/35/19....
Supra NA-T
Total Annihilation
Nov 7, 2010
442
Leesville,La
I am looking at a pair of XXR 502's and wondering if these would work with the offset... not really too sure when it comes to staggered wheels and offsets so any info could help.18x7.5 +42 for front and 18x8.5 +35 for rears would work without issues besides rolling fenders?
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
supraholic you think 18x10+20 in fronts with slightly pulled and rolled fenders will fit and 18x10.5 +20 with rolled and flared rear fenders will work?
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
Just got my ccw lm20 in. The fronts are 18x10+20 as you see in the provided pics. Rears with be same offset but slightly wider
ohyeaitszac
Baltimore MD
hey guys i have a set of Borbet Type E wheels im tryin to get some opinions on what color to paint the center of the wheels im going to polish the lips. The car is going to be Cadillac Escalade White it is kind of a cream pearl white color, with the brown and tan interior?
atlpd3147
kool member
Nov 26, 2005
485
Dacula,GA
1Supraholic;1643030 said:
yes it will but will have to run stretched tires 225/35/19 (a brand that can be stretched) & 255/35/19.
I assumed u meant 18's. But that's Kool thanks for the info. I will do some research and find the best tire brand that can stretch well in my given application
Falken
294
Los Angeles
R3N5LOW;1550165 said:
ah nicee i'm using tt wheels with spacers as well
i'm running 245/45's up front with a 25mm spacer with a slight roll i still have to lower it a bit more. I was hoping it'd be a little more flush but i dont want to run anything bigger then a 25mm spacer so i'm pretty happy with the results
and 275/40's in the rear i have another pair of 25mm spacers on the way with some fender rolling work on the way as well;)
sick man... thats what ima do to my ride, what kind of spacers did you use? does type matter?
scotty
476
Norway
scottnicholas.net
Finally someone's got LM20s! Thinking about these rims my self but not many on MK3s to see how it looks.
Please post some pictures when you've tires and car is on ground. :)
usdm_anon
92
Madison, WI
laotionracer101;1641206 said:
Anyone know if there was ever a supra to look good with Watanabe's?
Yes, they look great
not my car don't know the sizes
On a side note I want a similar wheel setup to this
I'm thinking ssr sp1 professor, or work meisters in 17x10 -8 offset in the rear, I know I'll have to roll fenders but will it work without serious pulling?
projectsupra
旧車スープラ
West Palm Beach, FL
s235.photobucket.com
8" +20mm? I suggest between 215 and 235 for the front, it all depends on tire brand (actual width of tire), camber, roll/pull, ride height, etc. Should have no issues with any 255 for the rear, more if your driving a monster truck or rolled/camber.
Also good luck with 10" -8, I had 275/11" +10 which is -5mm in and that was max unless you run more camber and even more stretch.
Also the red 70 with Watanabe's is widebody, that's why they look so good.
