What IC hard pipe size would you recommend for this supra?
arod
7MGTE
Mar 25, 2007
Bayamon, Puerto Rico, Puerto Rico
I am going to make the IC hard pipes upgrade and was thinking going 2.5" all around but I have a friend (he has a MK4) that is telling me to go with 3". I do not want to suffer from much turbo lag and I think 3" will be overkill.
This is my car setup:
7MGTE with R154 trans
3" exhaust no cats
FCD
APR Head Studs
MGH
Garret TO4 60-1 with modified CT26 housings
(Here is a link to it: http://cgi.ebay.com/ebaymotors/ws/e...40246158042&ssPageName=ADME:X:RTQ:MOTORS:1123 )
Spearco Intercooler
(Here is a link to it: http://cgi.ebay.com/ebaymotors/_Car...hash=item150267539734&_trksid=p3756.m14.l1318 )
My power goals are 400-450 RWHP (I know I need more stuff for that like injectors ect.) what size would you recommend.
Thanks in advance
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
i'm going 2.75 with a similar setup....but I'll be moving to a bigger turbo shortly, so I'm giving myself some room to grow.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
s383mmber1;1075291 said:
Its listed for an MR2. These turbos DO NOT fit.
Umm... it's a single entry ct 26. They are identical unless he ships a twin entry.
It fits.
Oh i am going 2.75 for IC pipes. Why? Because that is the size of the TB.
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
My power goals are 500-550rwhp and I believe 2.5" is sufficient. Maybe could use 2.75" But since that is my max goal and going for 450rwhp daily it keeps lag down and is more drive-able. Also if you are not running a FFIM I would go with 2.5 or 2.75 not 3" because you are gonna have a good bit of lag!
HTH,
Seth
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
540rwhp (630 HP flywheel, 844 CFM) according to the not2fast.com calculators will require 3" IC piping... 470rwhp (740 CFM, 550 HP flywheel) is the upper limit for 2.75". From 470rwhp-540rwhp, 3.0", from 540rwhp to 660rwhp, 3.25". That's with assloads of assumption, such as a constant 15% drivetrain loss, assuming that this calculator has a correct CFM to HP ratio, etc. etc.
