What a dead hole!
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
NashMan;1738710 said:
i drive my car in the summer for weeks at a time then it blows up hahahahah errrrrr boooo whooooo sniff sniff
I guess 2 weeks technically counts as the plural of weeks...
That's if his car even exists, I'm starting to think he's actually poaching shots off the internetz, photoshopping them a bit and presenting them as his. That and bribing the other two island guys with beer to back him up by claiming to have 'seen' it in person.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well I drop by filters off at the muchine shop yesterday
I have bad feeling about these piston might have been made bad as in mabye there off cliter and the thusting part is off to the side or some thing or they just did a bad hone or ring gap or just plain bad ring
i thinking is ring gap issue more because it only happend to the one cylyinder
and i used sip richs specs on every thing for 10 30 oil
I do know that the piston I had had the oil releafs on the wroung side of the piston
NashMan
Aug 5, 2005
4,940
17
Victoria BC
GrimJack;1738881 said:
Is a ring gap going to cause a drop by that far on the compression test? I'm thinking not... I've seen compression tests with better results where a couple inches of the top ring was gone entirely.
last motor had a comp ratio of 80 and the ring just de-seated good old stock shitty ring wiht lots of miles on them
but soon i will find out
soup
fiend
Apr 4, 2005
233
Vancouver
Enraged;1738896 said:
that might be true if he had anything other than Lucky Lager.
you miss it when you're not on the island.
Ryan, think you'll get it running by this summer's end?
NashMan
Aug 5, 2005
4,940
17
Victoria BC
It really depends on what went wroung if it is just a ring and needs to be honed yae should have it done
NashMan
Aug 5, 2005
4,940
17
Victoria BC
cords alpine
motor is out so gonna ripp the head off once I get coffe sun kinda wiped me out today
teh more i think of ti the more i think it is rings
NashMan
Aug 5, 2005
4,940
17
Victoria BC
wow number 2 is screwed and 4 has nasty line
poor job on ring fittment
