Tweeter position for a 91
caballo
78
So Cal
Do the stock speaker pods for a 91 have mounts for a tweeter?
I am thinking of buying this really nice set of tweeters but I am not sure where I will mount the tweeters. I am trying to keep this install as clean looking possible.
My car is in the shop so I cant really take a look.
These are the tweeters http://cdtstore.com/tweeters/es-010.htm
I need a picture of a speaker pod with factory everything, but I cant seem to find one. help please.
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
There is no stock spot. Look at my build thread for what I did to mine. Keep in mind you cannot reverse the holes you cut in your door pannels (duhhh!)
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
Just realized, you're planning on spending a good amount on them, i'd fiberglass them in that triangle spot stated above and you're going to want to get your whole system tuned afterward to fully benefit from those tweets.
Backlash2032
1,823
Nebraska
There sure is a stock spot on 91s and 92s. The factory 6.5 speaker mounts have a spot for a ~1 inch tweeter right at the top.
caballo
78
So Cal
Good thing I haven't bought the little bracket mount yet.
OfnaRcR4
Shea!
Oct 2, 2006
1,340
kettering ohio
Did only some get them because mine and all the ones I've seen don't.
Backlash2032
1,823
Nebraska
Well I have a set of factory 6.5 mounts. Did you buy the aftermarket set?
Sent from my terrible HTC Rezound using Tapatalk. Don't buy HTC...
Scott 88-1JZ
122
California
The 6.5" speaker pods I bought from an 91-92 supra had the spots for the tweeters. Only problem is they were small and I had to trim around where I wanted my tweeter to be to make it fit perfect.
Canuckrz
852
Calgary, Alberta
IIRC there was an old thread in this section where someone said a certain year of celica convertible had tweeters in that triangle behind the mirrors and they were almost a perfect fit for our cars. Don't remember the year or if anything had to be modified to mount them however. Might be worth digging into if you were so inclined.
kunfusion
24
Indiana
I have been reading in the 91-92 6.5 mounting boxes there was a small hole intended for better bass from the speaker which "could" be used for a tweeter. That doesn't entirely mean that is why it exists, but do as you will.
simmi
25
Rajathan
Good stock...
