Original Explosive Material - Tobes' Build Thread
loc182
283
11
Grove City, Ohio
They say always leave them wanting more, so this will be a slow build thread ;)
The Supra has run well since 2013 despite my rushing into things, largely thanks to many posts on this forum. However, something has felt off for a while and it looks like my luck has finally run out:
Machine shop will get the head once I can find one in the Columbus, Ohio area to do cleaning and timeserts on the exhaust studs that came out. I have my own cleaning to do as well on everything else.
The temporary goal is to get the Supra running again with a stock gasket, and wait for warmer weather to pull the engine to get it prepped for metal and ARP studs.
Massive thanks to Jeff and everyone involved in bringing Supramania back, I am very thankful to have this wealth of knowledge and Cygnus-X1 as aids in this rebuild.
  • Like
Reactions: supraguy@aol
loc182
283
11
Grove City, Ohio
Head is back with time-serts and the OEM exhaust studs I bought in 2013 are finally out of the package and living their best life!
Got some cleaning to do, but I can finally start getting ready to reassemble.
  • Like
loc182
283
11
Grove City, Ohio
Unless your power goal is above 350hp, a Felpro head gasket with ARP's at 75ftlbs will last forever.
Is that 75 with using their lube? I have the undercut head studs because I heard they are better with a composite gasket (mine is Ishino Stone, looks like an OEM). The instructions say 90, but so many threads say 80.
What is the best thing to do?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,282
72
Atlanta
If ARP says 90, then go with that, using their moly lube. I said 75lbs, because I thought you were using ARP head bolts, not studs.
  • Like
Reactions: loc182
loc182
283
11
Grove City, Ohio
Cleaned up the head today and finally installed the EGR cooler gasket and bolts I bought in 2013. I foolishly thought I could change that with the head in the car.
However, I did manage to change that water union and banjo pipe with the head in the car in 2013. It really thought it was never going to come loose and the original union looked terrible. The new one still looked pretty good, but a new set was cheap and my oh my is it so easy with the head on a bench :D
Valve cover No 3 still looked and felt alright after cleaning, so I decided to give it another go instead of using the NAPA drain plug gaskets. I did torque those plugs to 26 though at a recommendation. When I took them off originally it took a breaker bar and all my strength and nearly broke my new at the time 14mm Allen socket. I wonder if the TSRM value of 13 ft-lbs is just for the bolt that sits in the last plug and they left out the true torque for the plugs? All four of mine were loose when I started pulling the car apart this time.
Tomorrow I should be able to put the head back on and begin getting the car back together!
loc182
283
11
Grove City, Ohio
Sadly I don't have a 12 point 14mm deep socket, so no reinstall for me. But I did follow the TSRM for the head reassembly. Seems odd to put the intake on since the head is heavy enough without it, but it is not like I could get the head in position on my own.
The rubber on the injectors was hard plastic, so it was nice to refresh the o-ring, grommet, and insulator before putting them back into their original holes.
I am a little concerned about where to put the forward VSV. The TSRM notes to install it with the intake, but I have no images of its location. Time to search!
Issues aside, thanks to Bru's post on Toyota of Decatur I was able to justify the original hood shocks and I put those on today! The Stabilus replacements didn't last all that long and I was glad to see them go!
If only Tokico Illumina IIs were so easily sourced!
  • Like
loc182
283
11
Grove City, Ohio
One 12-point 14mm socket later the head is back on and torqued in three passes. I don't know how you guys do these jobs in a day, this took me hours. But all that thread chasing sure made the studs easy to put in.
Now I just have to put all the really fiddly bits back on :D
supraguy@aol
Well-Known Member
Dec 30, 2005
4,282
72
Atlanta
Before you part out, consider going to 7/16 studs; That's what I did.
If the holes are too big to tap to 7/16, you might be able to go to a 7/16 helicoil.
  • Like
Reactions: loc182
supraguy@aol
Well-Known Member
Dec 30, 2005
4,282
72
Atlanta
I am worried the holes are too big now, but I will ask the shop what they think. Time for a true Project Hail Mary!
I just checked with my friend Google, and he says that the drill hole you used to put in a 10mm timesert was 13/32.
The proper drill bit size for a 7/16 timesert is 29/64. In other words, you should be fine to upsize. But bear in mind- 7/16 itself, is 28/64, so 1/32 larger than your current drill-out size, meaning, you could likely just unscrew those bad timeserts, and straight-up lube and tap to 7/16.
  • Wow
Reactions: loc182
supraguy@aol
Well-Known Member
Dec 30, 2005
4,282
72
Atlanta
I have noticed a lot of recommendations for FelPro head gaskets. Are they better than Toyota OEM?
I think they are just the next best thing to OEM. I don't know if they're better. I used Felpro and ARP's a long time ago, and had no issue for 3+ years that I ran it that way. I only later changed because I changed engines.
  • Like
Reactions: loc182
loc182
283
11
Grove City, Ohio
Thanks! I was worried going OEM might have been a mistake.
The OEM (bottom) is very sticky compared to the Ishino Stone (top), and it has some green stuff on it I assume is extra sealant. Otherwise they are very similar.
  • Like
loc182
283
11
Grove City, Ohio
What did you decide to do about the exhaust studs?
I missed this one! The shop tried another type of insert and this time 5 of 7 held torque.
I only had 4 of 7 holding torque before and things were good for many years, so I decided to start putting things back together.
I will have to use the Driftmotion kit when I pull the engine next year, hopefully it will make everything better.
loc182
283
11
Grove City, Ohio
After countless problems I finished the car last night and it started right up today after the no EFI cranking! Well, it took some time for fuel to fill the rail of course. And no codes shown when I was checking the timing. Hooray for no electric woes.
Still feels like an old car, but hopefully new head gasket is happy and like the Offspring once sang, keeping em separated. (Oil and coolant that is.)
