The TEMS System and HKS EAC-T Bible
May 18, 2007
704
Aarhus
Just got my HKS TEMS controller wired in. It seems to work setting the suspension.
One thing though I don't have any light in the buttons. The LEDs over the buttons work, but there is no light in the buttons.
Is that right? Or should there be light inside the buttons too? Looking at Crisps avatar it seems to be the case, but I have seen other pictures of HKS tems controller with no lights.
crisp
existentialincrementalist
May 25, 2007
1,785
Ohio
All buttons should light. Red when depressed, Green when in raised position. Always on Red or Green.
G/L!
-crisp
May 18, 2007
704
Aarhus
Well as I wrote the LEDs on the top all work and now I took it apart and there no other LEDs inside the controller.
So if the LEDs on the top work then the lighting works. The buttons themselves have to lighting. They only get lit up by the small LEDs on the top.
May 18, 2007
704
Aarhus
I have the final wiring diagram here:
In addition the short black/white wire with a spade goes to 12V and the black wire with the ring terminal goes to ground.
crisp
May 25, 2007
1,785
Ohio
Perhaps we have mis-communicated. The buttons themselves have NO lights (LED) INSIDE of them, rather, they ILLUMINATE due to the LED's inside the UNIT near or under the buttons.
Is that clearer and how yours works?
Keep in mind, my PICTURES are well saturated and amplify the amount of color and light you actually see. The buttons are NOT as bright as many of my pictures I have posted under natural conditions. ;)
-crisp
May 18, 2007
704
Aarhus
I'm working on a small print that will make it possible to keep the squat function when you do an engine swap (like me going 2JZ-GTE). It will also in theory make it possible to keep the original automatic gearbox and gearbox controller.
If it works we will be manufacturing a few sets if people are interested. It will need 12V, ground and the TPS voltage and will output the L1, L2 and L3 signals that are needed by the TEMS computer (and ECT computer).
May 18, 2007
704
Aarhus
Am I supposed to be able to select firm in both auto and manual mode or just in manual mode?
I can select firm in both modes. Is that right?
May 18, 2007
704
Aarhus
I now have working squat function with a 2JZ-GTE and an Apexi Power FC ECU. I used the Arduino platform to simulate the L1,L2 and L3 signals.
I'm sure it can also be used to keep the original automatic transmission controller with the 2JZ.
BoostMonger
PUSH IT TO THE LIMIT
Sep 5, 2011
880
Shadows of Utah
-crisp
I just installed one, can confirm your pictures are deceiving ;)
