Doat;2048991 said:I had a targa leak but I replaced the seals and added silicone following the step by step guide and that stopped that leak I also replaced my tail light gaskets and awhile ago I did the rear hatch seal as well. When I open the hatch water drips from the trim panel on the right side. I need to remove the spoiler one day and seal that up and the wiper arm but not sure how to remove that.
Pull that trim piece off and try and see if there's any visual clues as to where the water is coming in from. You should be able to see the dirt is in a kinda "flowing" pattern from wherever it is leaking in and moving the dirt around.
