taking out the engine without a motor crane? possible? how to?
Persona
20
Warm bench
hey folks. i got another bhg and want to go the mhg route now.
i dont have access to neither crane nore lift but want to do the work myself.
did anyone removed the engine without those, maybe have a self built mechanism or trick i could copy :naughty:
cheers!
Keros
Canadian Bacon
Mar 16, 2007
825
Calgary
You could build an A-frame out of 6x6 lumber... but I'd recommend renting a hoist because I hear falling engines aren't good for your health.
Athena
Rawr
Jun 22, 2009
154
Raleigh, NC
You could rent one for a day for about 30, or the week for under a 100 easy.
I think I've seen them to buy for around 200-250 with Levelers.
It's worth it.
Christopher
supersupramk3
average joe
Mar 29, 2009
145
sacramento, CA
This post is hilarious!!!! Harbor freight i think sells em pretty cheap...by the time you go buy 2x4 and nails and build the A frame the time spent is not even worth it. Or if your good at welding just cut the front half of your car off then re-weld later.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Seriously... I bought mine 5 years ago for $150. It's pulled at least 12 engines so far, including several 7M's and a 7.3L powerstroke a couple times.
They're worth the money.
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
bought mine for $100 canadian
if you are going through the trouble of decking head and block for mhg... why not just save yourself trouble and get a crane... cheap easy and safer than any other way...
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
Got mine new for $120, its a torrin big red from pep boys. Been outside for almost 5 years and it still works. If you cant afford that find a used one on craigslist. You will spend more than that if your cheap ass contraption fails and smashes your front end.
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
Harbor Freight has them for $150 dollars . Go buy one use it to take out the engine then return it with in 30 days. Tell them that its DEFECTIVE hint hint and get your 150 back. Dont loose the ticket. Good luck
