taking out the engine without a motor crane? possible? how to?
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
wardog;1519807 said:
Harbor Freight has them for $150 dollars . Go buy one use it to take out the engine then return it with in 30 days. Tell them that its DEFECTIVE hint hint and get your 150 back. Dont loose the ticket. Good luck
this is what's wrong with America today..
92nsx
2,957
Clearwater, MN
You should be able to find a good used one in the 50-100 range, if not a new one. It will pay for it self the first time you use it. If anything think of it part of the cost of install a MHG. Plus a hoist is cheaper then most MHG's out there.
wardog
R.G.V WARDOG
Jan 19, 2006
564
ALTON, TX
Just think about the $600 dollar labor charge at a shop to remove/install the engine. Just go buy/rent one, the experience from doing the work yourself is PRICELESS. You will learn alot about the car, good luck and let us know what route you talkng :beer:
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
A load leveler is something you might think about getting with your hoist... Wish I had one when I just took my motor out and put it back in...Huge PITA without one.
kcheng
mkii 7mgte
Nov 22, 2005
117
bby, bc
im junking a car and i dropped the subframe because i cut the lower rad support. wouldnt recommened this method if you are keeping the car lol
do562000
oregon
supersupramk3;1519744 said:
This post is hilarious!!!! Harbor freight i think sells em pretty cheap...by the time you go buy 2x4 and nails and build the A frame the time spent is not even worth it. Or if your good at welding just cut the front half of your car off then re-weld later.
i got my from harbor for 168$ and i v use it lots alot worth the money man
