Supramania's Elite Engine bay Thread...ZERO progress pics.
polobai
Orlampa
I relocated the fuse box to the drivers side fenderwell in front of the wheel. Its a bit harder to get to but it cleans up the bay nicely.
HKS_TRD
998
Australia
Do you have any issues with it getting wet or have you got some form if weather protection. I am thinking I wilk open up the body loom and relocate the fuse box to the glove-box.
7M-KDL
Seeking high numbers
polobai;1850138 said:
Thanks I moved the filter because I was getting pressure loss with it higher than the engine and drainback issues. The material I used to cover the intake manifold, intake, valve covers etc Was a product called "Neefy wrap". It's a carbon fiber fabric. It's not self adhesive so if I did it again I would use a self adhesive material like 3m dinoc. I Love my Pwr radiator-works like a champ-never sees above 180 while cruising and only have to use the electric fans in traffic. I like your car also-clean and simple.
Any more detailed pics of valve covers and center cover?
polobai
Orlampa
Not currently. I think if you search my username there is a build thread from a few years back. There may be pics in there. No problems with moisture where the fuse box is-I try not to drive in the rain but when it gets wet there are no issues.
Dec 31, 2010
216
IL
Hottscennessey's 700hp Meth Monster! (Mine now)
dslocal
340
slo
Try routing the booster hose under it instead, plug off or finish removing ac ports and a sparkplug cover. Other than that beautifully done sir.
