Supercharger on a 7M
Kai
That Limey Bastard
You're thinking of the Lancia Delta S4 - 1.8litre DOHC - twincharged, more than 600bhp and did 0-60 in 4secs on gravel ;)
The Peugeot Group B rally 205 T16 was a midengined RWD turbo jobby.
VW/Audi/Skoda/Seat have some twincharged models in their lineup these days iirc...
SupraChrisMk3
New Booster
Feb 8, 2006
170
Salisbury, Vermont, United States
On a twincharger setup to make the turbo spool up quicker wouldn't you wan't the supercharger feeding the turbo. Not the other way around. In this setup though it looks like the point is for the supercharger to provide the low end power until the turbo kicks in up higher. Maybe I have the idea wrong but either way it's still badass.
because they work?
Anyway, one of the ONLY supercharged 7M's I've seen, and it's also turbocharged. I would love to see the dyno sheet on this...
They make twincharing setups for the mini cooper S as well. So far as I know twincharging is insanly powerful and banned in quite a few racing circles...
OMG that vid of the Lancia is pure sex!
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
In way i kinda get what your are saying but not really
The supercharger does not feed the turbo ...... It adds usable power until the turbo spooled the same way NO2 would. But the difference is "You dont run out of boost"
Spaniard
524
La pearla PR
My hat goes off to that gentleman. Very cool ingenuity! I have worked on and got running a supercharged svt that was turbo charged as well. It was insane. Very good performance can be see from this setup people, dont doubt it at all. I would love to see a dyno sheet of this 7M.
Again, very cool. Two thumbs up!
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
So how would it be set up? Using some kind of valve system to separate the turbo from the intake until a certain boost is reached?
twincharger doesn't matter the order, since the more air into the engine (fed from the supercharger) means more out to spool the turbo...
it works, and i have less IC piping...
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
No dyno or track numbers yet. This is just his stock engine used for mock up. he's working on a full built engine and it will be ran with an AEM.
There's no aftercooler. There was barely enough room to fit the supercharger on without hitting the shock tower. There is maybe 1/4 inch between a bolt and the shock tower. He's using a 4 inch intercooler up front, so that should be enough cooling.
When's he's done, I will post more pictures and a video too.
