***SM Member Horsepower List***
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
If by treachery, you mean I've been outside working on my car instead of editing lists for you guys, then sure, I guess.
If you look back at the history, you'll notice this list has occasionally gone MONTHS without being updated. Five days isn't even worth mentioning.
Turbo Habanero
4,229
Tucson,AZ
Plau000;1945324 said:
I'm wondering why you Moderators haven't added LAZER1100 to the Dyno list? He did everything you asked, except mention he has a 255 walbro fuel pump, and yet he has not been added to the list. There seems to be some treachery afoot.
Albert;1945328 said:
Cause he didn't make 700 duh
Lol
Shame on you Grim =p
But you still have not updated lmao
gilbertmk3
gilbertmk3
May 28, 2007
7
St-Goerges Qc
7mgte : 407.7 hp 5889rpm - 377.4 trq 4966rmp
build block
small porting head
stock cams
ct2657
front intake
ddp,straith 3inch
flex-a lite,mishimoto
fmic
denso 550cc
walbro 255lph
Megasquirt 2
etc
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
toyotanos;1944113 said:
toyotanos - 788whp/674 rwtq - 7M Eagles/83.5mm JE's, AEM, 1350's, E-85, Billet 6765 @ 31psi, +1mm valves, dual springs, P&P, BC 272 cams.
there, it's copy/paste ready!
Excellent. I like it when it's easy. Updated.
lazer1100;1944217 said:
Here is my Dyno sheet. Current mods: Stock 1jzgte , rebuilt twins at 18psi, mines ecu, SAFC 2, full three inch fencepole and turbosmart manual boost controller. Black is first run blue is second got very heat soaked was over 100 degrees that day.
Added.
Plau000;1946890 said:
SMH! Childish
This is akin to complaining about the brand when someone gives you free beer. I'm not a servant. I don't get paid to do this. Hell, it wasn't even my idea - I just picked it up when the last guy retired because nobody else would. It's this kind of nonsense that makes me understand why the last guy wanted to retire.
gsxr141;1949064 said:
here's what my car did. the only mods are......... 600 injectors, lex afm, k&n filter, hard i/c pipes, bic ddp+ full 3" exhaust. the boost controller was set to 15psi. it's a lot faster than before the lex/550 setup. also, it was hitting fuel cut all the time.
https://sphotos-a.xx.fbcdn.net/hphotos-prn2/1044049_635834696427669_1432321517_n.jpg
What's wrong with this post? Let me count the ways... ;) Seriously, you need a dyno sheet / screenshot that isn't cut off so bad I need to use interpretation skills... and it helps if you post your engine type. I'm guessing 7M, but that's just a guess. If so, you've got some work to go yet, the minimum to get on the list is currently 422whp.
build block
small porting head
stock cams
ct2657
front intake
ddp,straith 3inch
fmic
denso 550cc
walbro 255lph
Megasquirt 2
etc
Pretty nice, but you need to make over 422whp to get on the list at the moment. Time to crank that boost another half a pound!
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
BoostMonger;1958754 said:
Since alberts no longer 1j, is his numbers going stay up or can i snag the #1 spot from when im tuned?
There are a bunch of folks that aren't valid anymore - people have sold the car, blown up their engines, parted them out, etc. We don't drop them from the list... so the only way to take the #1 spot from Albert is to actually push more power than he did.
BoostMonger
PUSH IT TO THE LIMIT
Sep 5, 2011
880
Shadows of Utah
I'll settle for second...
Sent From My HTC One S using Tapatalk 2
gsxr141
1,158
10
rochester
sorry grim. i didn't know there was a minimum power requirement. :/ i thought the numbers were pretty good for a half dead, mostly stock engine. hell, i only threw it on the dyno for shits and giggles.
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
No worries. Technically, it's not a power requirement. We only track a certain number - otherwise, we'd have 12,000 members wanting to be on the list. First of all, vBulletin would buckle like a cheap tent if we tried to keep track of that many people in a single thread, and secondly, keeping it even vaguely up to date would require a full time staff of several people.
So, we set the 7M limit at the top 30, and the other classes at the top 15. As more folks get on the list, the 30th spot moves up in power, of course.
toyotanos
What will we break today?
2,844
Coon Rapids, MN
Terry, what were your numbers- nobody wants to guess based off of a sheet that has fuzzy graph lines...
Terry steward
53
benfleet essex
Ah,,Just over 400 Bhp at the rear Wheels,,441.4 Bhp/5621 rpm and 490.6 lbft at 4232 rpm,,,it made 300 lbft torque at 3000 revs
441.4 and 490.6 was At the fly figures
Oh,,sorry thats at 19psi,,,the turbo is capable of 30 psi Apparently
GrimJack
Administrator
Dec 31, 1969
12,377
idriders.com
If you read the first post, you'll notice we need corrected wheel numbers, engine type, and mod list.
If this is on a 7M, you've got some work to do yet, 441 BHP = ~385 WHP, and you need over 420 to make the top 30, which gets you on the list at the moment.
Terry steward
53
benfleet essex
Ah right,,he did say it was just over 400 at the rear wheels,,and I believe he estimated what it would be at the fly,but Seems he has Estimated losses of 10%,,Whereas I've Heard auto losses are more like 20-22%,,But yeah,,further Mapping to 21 PSI,would I imagine raise the power enough to get on the rung
And I have Done a mod list on the Aem posting I did.
Actually on my thread Titled "Hi"
Note: Multiple posts merged by Toyotanos- please use the edit function if you need to add additional information to a post you made prior. Having 3-4 little posts can clutter up a thread in a hurry. <3
