Short throw shifter on a budget
tylerjacobsen85
WVsupradriver
Nov 28, 2005
135
Morgantown, WV
I got my hands on a incomplete C's short throw shifter kit with a front clip. I haven't been able to find parts to complete it.
I decided to take madders in to my own hand by fabricating my own parts. I started off buying a w58 shifting retainer for 15 bucks shipped to my door. I then started cutting and grinding.
[/IMG]http://photos-b.ak.fbcdn.net/photos-ak-snc1/v2561/161/102/25820446/n25820446_39066017_1996184.jpg[/IMG]
[/IMG]http://photos-d.ak.fbcdn.net/photos-ak-snc1/v2561/161/102/25820446/n25820446_39066019_2561861.jpg[/IMG]
[/IMG]http://photos-h.ak.fbcdn.net/photos-ak-snc1/v2561/161/102/25820446/n25820446_39066023_3568296.jpg[/IMG]
http://photos-f.ak.fbcdn.net/photos-ak-snc1/v2561/161/102/25820446/n25820446_39066029_1954028.jpg
The top half of the shifter is missing so it was too short to test out. So.... I made one out of some fire wood. :naughty:
It shifts awesome, It turned out way better then I though it would. What do you guys think?
tylerjacobsen85
WVsupradriver
Nov 28, 2005
135
Morgantown, WV
gaboonviper85;1267589 said:
i have a long hard piece of wood you can wrap your hand around......
Ill have to pass, maybe you should ask a girl to do that, just a thought.
Im not going to have the wood shifter for long, I just put it on to test it.
kotu100
1,899
Easton, Ma
sooo, theoretically, you could do this with a stock shifter if you just cut/weld to extend the bottom part?
and i just gave away my extra shifter too... :(
tylerjacobsen85
WVsupradriver
Nov 28, 2005
135
Morgantown, WV
Ya i guess you could do that. I did it this way because it was cheap and I don't have a welder for aluminum. So I stacked the retainers. I think im going to call it the short throw stacker.
Keros;1267716 said:
I was skeptical at first.
But that was halarious. Nice work.
Thanks for the comment man
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
the only down fall is if it does not sink in well you can mess stuff up over time and were stuff out aka extetin the shift rod and cheax stuff apart
i took apart 2 trannies maken mine to get the right setup
viper92086
932
NJ
i've done it, i made a thread on here a while back with pictures and everything. still using mine. its been awesome
tylerjacobsen85
WVsupradriver
Nov 28, 2005
135
Morgantown, WV
Im pretty sure that it will be ok, everything lined up and the length is good. Im going to take everything back apart and double check everything. Thanks for the concerns. Hopefully i won't have any problems.
