San antonio
Suprapowaz!(2)
2,870
San Antonio, Tx.
Did the 12v mod this morning. Tweaked the afpr at idle to satisfy Vf. Car runs good, but still goes rich under full boost. It did clear up the lean spot between the 9v to 12v transition though. I need to adjust the afpr and lean out the top end without affecting the idle/cruise performance much. All in all it runs pretty darn good.
sterlingae
175
Austin, TX
Ya in Austin at oasis on lake Travis. I'm just going to bs with people rather than stay home. Hardparked cars sucks but nothing else going on..haha
sterlingae
175
Austin, TX
For some reason the dp flange is giving me hell. First one I welded wrong so i grinded it down and rewelded it, that leaked so i bought another flange and a graphite gasket. Welded that on correct but I took it for a drive and only help 6psi for maybe two pulls then spiked back up to 15psi. I think i may have warped the flange when I welded it.
sterlingae
175
Austin, TX
Fuel pump is pretty simple if you buy a fuel pump controller out of a is300 or gs300. I have mine running off the factory s13 wires but a switch to turn on the relay.
S.A. supra
2,405
Buda, Texas
Ok yeah I was thinking about going to a switch, if I can't get the stock one to work. My fuel pump will only kick on if I tap the main relay.........???? !!!! I can't figure it out.
Suprapowaz!(2)
2,870
San Antonio, Tx.
It's possible you did warp it. If you tried to weld a continuous bead around it that's too much heat. I try welding an 1 - 1 1/2 inch at a time and give it enough time to cool down in between weld time. I just don't see how a DP flange leak would cause a boost spike.
sterlingae
175
Austin, TX
Ya I did it all at once. Il get another I guess. It needs backpressure from the downpipe on the stock twin turbos or it will boost spike from having too small of a wastegate port.
S.A. supra
2,405
Buda, Texas
I fixed my fuel pump problem. it was a problem with the alternator, I forgot to tighten the wire that runs back to the battery, and when the battery runs low it doesn't kick over the relay. with a fully charged battery the pump kicks on every time now.
Suprapowaz!(2)
2,870
San Antonio, Tx.
Cool. Remember when I couldn't get my car to start? I borrowed your starter and tried it and it still wouldn't start. Turned out that I didn't even have the starter cable hooked up to the battery. :icon_redf
So what's next... mid pipe?
S.A. supra
2,405
Buda, Texas
Yeah, I remember. I just finished tightening it and what would you know, battery light is off and it fires up every time. Now to fix a leak I have at the bottom part of the return line.... then around the block to see if my brakes work. If all goes well next week i'll take it to get the mid pipe done.
whitehat89
227
San Antonio, Texas, United States
Sorry this is a few days late, ive been up to my eyeballs in family and work... Here is my birthday present from my wife this year...
Sent from my SCH-I535 using Tapatalk 2
