Project: Git'R driving...a VERY short build
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Well, I got the shift knob done.
PS- forgot to add to the to-do list:
Replace clutch(again). I bought a stage 3 clutch a while back, and need to install it at some point. The existing clutch doesn't slip yet, but it's close.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Another update:
Since I had gone ahead and pretty much violated the original plan of keeping the car stock,
I thought I may as well find out what all my updates had done to the car.
To recap:
Apexi intake
HKS super drager exhaust
3" down pipe
57 trim turbo
560cc injectors
Lexus afm
Apexi neo fuel computer
Manual boost controller:
I have no idea what the boost level was, since I have no boost gauge. All I know is that the stock gauge would go to the top, and after smelling burning clutch on the first pull, I dialed the mbc back a touch, and no more smell. I'm guessing it to be somewhere around 10 to 12psi.
Also, this is with a catalytic converter installed, so I'm happy.
EDIT- After putting in a boost gauge, I believe I was at around 12-13psi.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
One issue I've had ever since I swapped the turbo and injectors...
The bypass valve never seems to open any more. I just get the rapid stutter of backpressure against the compressor wheel.
So, I upgraded my bypass valve yesterday, with the only oem-looking, plug&play performance bypass valve I know of:
Looks great, and fits great. Problem is it didn't fix the stutter/flutter problem.
There's vacuum at the line, but I suspect that the silicone vac hose is collapsing or something, when I let off the throttle.
Just another little issue to resolve, I guess.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
So...what's the latest?
I finally replaced my original oem pressure plate for a slightly stronger one, so hopefully, no more slipping clutch,
and I can add some boost. I won't do that however, until I install my boost gauge, so that I know what I'm running. I'm just waiting on a harness plug for it,
so maybe that'll happen next week. Also, I swapped the new FR500's from my '88 project car, over to this one. I want to sell off the XXR's, and get another new set of wheels for the '88.
You'll notice that I added a tint to the fog lights as well:
She's running well, and there's really only two other changes I want to do to the car:
New Tokico illumina TEMS struts
Euro half clear front turn signals.
THEN....I'm done.
....I think...
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Oops- I forgot to mention:
I ended up replacing my 12 year old CSF aluminum rad, because it developed a couple of very slow leaks.
Also, I bought new inner and outer tie rods, since they were rusted together and couldn't be adjusted. Also, new rack boots because the old ones were torn,
And new front wheel bearings, because the right side makes a little noise. But other than that....it's done.
....really....
OK. I also want to replace the windshield, to get rid of the little chips.....but THAT'S IT.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Well,
First of all:
FUCK PHOTOBUCKET. They are holding everyone's pics for ransom, by saying you have to upgrade to a $400 membership to get the linking ability back.
So, I have gone through, and painstakingly replaced all of my links(or at least as many as I could find) with those of a different site.
I am NOT looking forward to doing this on my other build thread.
That being said, The car is exactly the way it was, when I last posted, back in November of last year.
I haven't done a single thing to the car.
...ok... that's not quite true...
But not much has been done to it.
I did finally get both front and rear Illumina shocks, and those are in.
I replaced all of the intercooler hoses with silicone, after one of them split.
I rebuilt the diff with a Weir stage 1 and solid pinion spacer.
I replaced the rear subframe bushings.
I replaced the steering rack bushings.
I replaced the AC compressor and drier.
Oh, and I added a boost gauge, like I said I would. But where is it?
There it is...
Oh, and finally came across one of these little gems...
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Oh, and one other upgrade, and this one is also nearly invisible; a new intercooler.
I had heard that the stock one was good, but not great. I don't know if the one I bought is any better, but it is bigger.
Took me a bit of messing around, swapping couplers, and twisting things, but I got this one to fit in the stock location,
without it being obvious. Here's some pics:
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Other things I failed to mention:
I replaced the upper and lower hatch glass trim pieces with brand new units
New front tires
New windshield was put in back in April
Still on my To-Do list, are the following:
Replace the tint on both door windows. Its peeling a bit.
Replace the driver's side lower rear control arm. The camber bolt is frozen into it.
Re-remove the diff, and tighten up the pinion lash.
And truly, that's about it, until something breaks or wears out. I plan to dyno the car again this week,
just to see what it does with a clutch that doesn't slip.
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Jealous of that EAC controller. And that intercooler should be much more efficient.
Now get to work on the 88 Diego!
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
I was! just today! She's tuned well enough now on the DET3, that I will finish the last two wire connections, and close up the dash, and begin stripping the moldings and trim, for paint work. Not looking forward to it, yet looking forward to it as well.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Whadup!
No, The 88 will likely be a weekend car/ garage queen.
I was supposed to head out of town today on a trip, but the plane had an engine issue, so I was off.
Here's what I did today:
Don't know if they'll have a trip for me tomorrow, but the next step is to strip the doors of their interior panels, speaker pods, windows, moldings and trim,
as well as the door frame moldings and targa seals.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
One last thing(lol..."last thing"...)
I went back to the dyno the other day, just to see if a new clutch and intercooler would help matters.
Here is a best run from last year, and a best run from this year. Finally broke 300, and that's all I need from this girl.
It's on the '88 to make the real power.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
GC89;2095594 said:
How many pounds of boost was this on? Looks good!
Thanks- Approximately 12psi. The boost would hit as high as 15, then immediately back off to 12.
You can see where power plateaus at about 4200, then starts a shallower climb to max hp by 4800. It's even more noticeable on the torque line at the same RPM.
The theory is, that the spring inside my $8 boost controller can't handle 15psi, but I also suspect the oem wastegate tension might be a contributing factor,
so just 10 minutes ago, I shimmed the wastegate by 2 washers, just to make sure that the wastegate door stayed seated better.
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
You're running a 57 trim correct? The washers should help, in my experience most boost controllers, manual or electronic struggle near double wastegate pressure.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Yup, a 57 trim. And an update:
WOW. That 5 minute fix made a difference. I went from 12 psi, to holding 18psi.
Now I have to back down the boost controller, back to 15psi, lol.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
77
Atlanta
Been awhile.... FIVE YEARS, roughly.
I have FINALLY completed the replacement of ALL dead pic links on the this thread, which happened to be EVERY LAST LINK.
I hate photobucket.
Went to Postimage. Then THEIR links crashed. Thankfully, SM allows direct hosting now.
So... what's new?
Last time I posted here, I mentioned that I wanted to do a few last things to the car, like new windshield, repaint hood and targa, and replace tint. A few of those things I did, like the paint and windshield, a few still remain.
Brand new complete paint job... Teardown:
