survyor2;1060802 said:
That one. I left it full size so you could see it (break out those reading glasses gramps!).
IJ.;1068673 said:Win for the old guy
The plug is the right way around but they're a bitch to get right!
IJ.;1068704 said:That's NOT an Oil hole whippersnapper :: IJ. ::
IJ.;1068714 said:One question first: How much HP are you shooting for with this engine Dennis?
IJ.;1068724 said:Personally I wouldn't use it
Is it an early light block?
IJ.;1068733 said:Looks like a late block.
It's the first I've seen with Deck cracks!
(were the bolt holes chased before the studs were installed?)
IJ.;1068738 said:DOH
At a guess I'd say that's what cracked it.
You get a buildup of crap in the bottom 1/3 that the bolts don't reach but the studs do.
Also looks like the block wasn't deburred after decking so that can contribute as well.
IJ.;1068749 said:Again personally I wouldn't risk it at that HP level, these motors move around a hell of a lot at high output.
Lower power with the holes washed with thinners and sealed with loctite you'd get away with it no probs.
I tend to be a bit conservative though so it's really up to you.
