When the car is cold and started up, you can hear the coolant flowing through the heater core.. and once the engine is warm heat starts coming out fine. However, when the engine is warm, and you turn it off and come back to it 5-10 min later and start it up again, it wont blow hot air.
Also, when the engine is hot, the upper rad hose is not hot and has no pressure when you squeeze it. I have replaced the rad cap and it has not made a difference. I tried to do a coolant flush, and the car would only take about 3-4 liters of coolant, so i put the cap on and let it run, and it started overflowing out of the reserve resevoir.
Wondering if I need a new thermostat or maybe a water pump?
The engine seems to stay right in the middle of the H and C mark on the temp gauge, and doesnt overheat.
On another note, the cruise control only seems to turn off and on within the first few minutes of the engine being first started when cold. Would anybody know if it is due to a vacuum problem? Not too sure what the problem could be.
Any help would or suggestions would be appreciated.
Thanks!!
Thanks!!
