New 7M Install
TweeT91109
738
Tampa, Florida, United States
OK good update tonight, got a good bit done, cant wait to work on the rods tomorrow. Anyways tonight, I sprayed the block, took the time to tape of the freeze plugs cause I like how the new ones looked, also I had my girlie and her friend help me spray it, so I taped off the important stuff. Ill be using some type of clear enamel to seal the unsprayed stuff. I also bought some plas-ti-gauge to just check the clearances given to me by my shop. All but one were right on the money. ONe just had a .001+ difference. I also took some pics so enjoy. Tomorrow Ill be taken the clearances on the rods, again just making sure.
Block side of the main bearings
Main cap side of the bearings
Me unwrapping the ton of plastic wrap around the freshly micro-polished crank
And handling the 75+ lb thing like a baby.
D.J.T.
877
Arkansas, United States
75LBS? Thats the block right? Because i don't think the crank weights that much. LOL.
Hope you used some kind of engine lube on the bearings before installing the crank shaft & pistons...
TweeT91109
738
Yea your right its probably not that much, but its still heavy
No I didn't use any type of lubrication on the bearings, crank, or pistons. I would have but I didn't rotate it, and I was again checking my clearances so you don't want any lube on the bearing anyways.
But when I go for reassembly I already have mono-lube for bolts, STP motor oil treatment (its a lot thicker and will stick for first start-up) for the bearings, and some SAE-30 just in case.
IBoughtASupra
4,455
Queens, NY
By Lucas assembly lube. I used it on my motor and that thing will stick. It is sticky and works well. Takes a long time to drain down but a film is still left.
Pull the fuse before starting the engine and crank to make sure you have good oil pressure.
TweeT91109
738
Yup I know about cranking it to create oil pressure, I did go buy some clevite engine assembly lube, and I was told to mix it with some SAE-30 weight, and it looks like honey lol.
Anyways, I have gotten the crank bolted down to 85ft. lbs. So today i'm also removing the rings off the pistons, and measuring the gap via a feeler gauge, I didn't know they were so expensive, but its a snap-on. So I guess its worth a motor, huh.
TweeT91109
738
Another good day at work ( I wish I did this for a living), got the pistons and rods installed today. The first two where the worst being my first time installing them, but after I got the hang of it the last four took as long as the first four lol. Before installing those I de-burred (I guess you call it that) the edges, of both the tops and bottoms of the cylinders. I want to keep the skirts pretty, hah, jk. Also oiled them up real generously with oil. Lined the oil rings up 180 degrees from each other, and also the 1st & 2nd compression rings. But 90 degreed those from the oil rings. All rings are 45 degrees from the rod line, if that makes since. Then moved on to the head stud threads, I was advised to re-tap them, then also chase them. So I did that, then re-chased all of them just for good measure, and reassurance of my mind. Got a few pictures of the completed work, and also got a shot of what happens when I get bored of chasing threads for 3 hours.
Pictures
This is what happens when you want to take a break from chasing threads, and its been raining for the last two days.
Bottom end shot
While chasing
Back to business
Im glad I was advised to tap and chase the threads on the head studs, cause there is a major difference in the depth they travel, I tried to get a decent shot on the difference and if you look close enough you can see how many thread are left out of the block
Now a bunch of random shots after I was done with it for the night.
dwhite
Tampa, FL
Where in Tampa are you? Thats the boat ramp at Lowry Park right? I used to live next door. I'd love to see your build sometime, wish I had the patience and attention to detail you have! Are you gonna keep the A/C? If not, I feel your pain that shit is the worst around here.
TweeT91109
738
Yea that's at lowery park zoo boat ramp. Yea I have a new evaporate and condenser already bought, and a set of 134a o-rings to replace all of them. And my girlfriends uncle works on car AC, and will charge my system for me.
D.J.T.
877
Hey what rims are those? I have the exact same things but mine don't have the center caps!
TweeT91109
738
OK I got the head on, it took me two times to place it. The first time in installed the head with the nubs on the block, then installed the head studs, but I couldn't get the washers to the head studs because they couldn't get past the studs, and valley of the valves. Anyways, I removed it again and installed the washers, centered them up, then installed it again with the studs in the block, and washers in the head, with no problems lol. So I got a few pictures of both of them. Both together once again.
I glue the washers into the Head with a dab of grease on each on then lower it over the studs as guides, no chance of screwing the poooch that way esp if you've recycled a MHG with Copper spray...
