Need help with 1.5jz build
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
22r would be sweet ;)
i hope your car gets up fastlike again :):) if it makes you feel any better i havent driven mine over 200 miles yet Lol keep finding little things to fix
dok33
My fuel pump precedes me
Apr 16, 2005
934
Austin, TX
suprahero;987886 said:
I'm about ready to just drop a 22R in there and be done with it...........:biglaugh:
I've towed a MKIII with a 22r, you'd be better off pushing it :sarcasm: Stay the course, I've got an M.S. in Mech Engineering and all this quench and c/r talk makes my brain hurt too and I'm supposed to know this stuff :nono:
Just my $.02 of non-expert advice, but it sounds like with correct cam timing you would have been ok on the old motor so I say take the requested measurements and resulting advice from the smarty-pantses here, pick a HG and adjust the cams again on the dyno. Drive the wheels off and enjoy the weather and maybe build a monster GTE on the side so you can get back on GTEpowered.com:naughty:
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
suprahero if it makes you feel any better i blew the head gasket in my 1.5jz yesterday doing a few 18psi pulls on the road in front of my house :( good thing i caught it right as it happend.
It doesn't make me feel any better knowing you blew your hg. I don't get any pleasure out of others misery. What head gasket was you running? Are you using a ge or gte block? Stock pistons? Just a few questions I'd like to know the answer to if you don't mind, and good luck on the new head gasket.
Did you measure your cr at all or did you just put a head gasket on it? Thanks, Jay
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
its a new fresh toyota 2jz-gte short block with stock gte head gasket stock pistons and rods.
iv got everything taken apart and cleaned ill be installing the new head gasket tomorrow and have some more fun tomorrow night. compression is whatever stock is with hks 272's
By new you mean the $2300.00 one from toyota? I thought about going that route myself, but when I found this ge block for $250.00 I thought I'd give it a try and then take my time building the gte block with new parts.
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
Yes like 2,300 dollars new i had the box it came in for a while untill i gave it away with the 1jz block since the dude was putting it in his car.
the ge block will be fine just get ready for the 8psi high boost lol :)
That's really not funny..............:aigo:
I may as well order another set of pistons and rods for my gte block or I won't sleep at night.
BJ, I don't think I have your number unless you sent it to me in a pm.
What do you guys think of these rods?
http://cgi.ebay.com/ebaymotors/TOYO...-BEAM-ROD_W0QQitemZ360040643081QQcmdZViewItem
I have a set of stock gte rods, so I don't have to buy any new ones, but I may as well if I"m going to rebuild the gte. What do you think?
I bought CP pistons last time, but I was wondering about the JE pistons. Are these any better or worse or the same as the CP?
http://cgi.ebay.com/ebaymotors/Toyo...ons-Rings_W0QQitemZ320238276918QQcmdZViewItem
My block is already bores +.020. The block still looks good though so it won't have to be bored again. I'm going to take it apart and double check everything before I order these though.
Here's the CP pistons with Eagle rods for $1129.00
http://cgi.ebay.com/ebaymotors/CP-P...4-2JZ-NEW_W0QQitemZ180232077573QQcmdZViewItem
Jay - I like CP pistons...got a coated set coming for the 7M. Not a light as the JE's, but the workmanship is superb.
If you are going to go that route, I would still measure the cc chambers on the 1J vs the 2J head. That way, you can adjust the CR with the pistons...just order a set to give you the same CR as if you had a 2J head on the motor. You'll keep the quench at near stock too.
Suprarich is a dealer...he can hook you up.
I got a call today from the company I"m getting my block from and UPS denied the package due to weight so they're having to send it freight. I then had to find a company willing to let me have a motor sent to their place of business. Hopefully now it will at least be on it's way here so I can do with it whatever I choose. I still don't know exactly what course I"m going to take, but once I get it here, I can take some measurements and hopefully make an educated guess............with the help of some of our members.
rakkasan
Currahee!!
Fort Campbell, KY
Damn Jay, I thought the 1.5 route was supposed to be an easy one. Your problems are starting to make me rethink going 1.5j since my 1j is running so good right now...
