Need answers to aluminum driveshaft questions
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
how about a one piece 3.5 inch aluminum driveshaft like Doward said, with larger U-joints, lighter, safe for high speed, cost effective and stronger then stock.
shaftmasters
Vendor
Oct 29, 2007
95
michigan
www.shaftmasters.com
Sawbladz said:
I would personally be very interested in the pricing that would be available for these driveshafts you plan to make. Are you able to estimate the cost now or will that only be available after you complete a test piece of each?
We have not priced steel yet but aluminum single piece shafts are $349.99 with Free UPS Ground to the continental US. Steel should be about $280-$300but like I say we haven't figured steel yet.
Thanks, David
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
David, welcome... I've been speaking to David for a bit now and he seems genuinely interested in helping this community with something it needs: driveshafts... I've read some of Shaftmasters' feedback on other forums, and from what I can see, they turn out a solid product... I would love to see something developed with a two piece, that would be awesome... Keep the ideas comin guys...
Dave, do you have any local Supras that you can get with and look over the stock ds to see what your feelings would be on designing a 2 piece?
shaftmasters
Vendor
Oct 29, 2007
95
michigan
jdub said:
AF1JZ nailed it in post #7 with IJ's comments. The downside to the stock 2 piece is the rubber material in the aft shaft. In a Supra, the 2 piece (assuming it's well balanced) produces lower vibration due to the harmonics involved. Plus, (like figgie alluded to) if you bust a one piece, you've just entered your Supra in a pole vault event ;)
I fail to see how by using a two-piece shaft that you eliminate the possibility of your vehicle pole vaulting. If the center u-joint breaks leaving the back of the rear shaft still connected to the differential and the rest of the rear shaft dragging on the ground how is it not going to pole vualt if it catches a rut in the road. This is what driveshaft safety loops are designed to prevent.
figgie
Twin Cities, Minnesot-ah
correct and specifically if you are racing under NHRA, the drive shaft loop is MANDATORY anyway :)
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Sawbladz said:
* adds driveshaft safety loop to list of things to do *
You wont need it... ;)
Pole vaulting a car? Myth Busters proved it cant be done, lol... That episode was hilarious... It royally effed up that car, but it didnt pole vault it...
figgie
sure you will! :) NHRA mandate :)
Now if you don't race, then no issues.
figgie
Reign_Maker said:
It was a joke... I was sayin he wont have the powah to worry, lol... *BAH! you kids!*
heheh
be like in the Transformers movie... Poopra splits in half and the front half rams aginst wall and the other half flips! :eek:
Well, I figure a high jump is better than a pole vault...since a 1 piece is twice the un-jointed length of the stocker. Not that it's really going to matter if the driveshaft drops and catches the ground anyway...it was just a way to point out it's very, very bad. If you're not using a safety loop, it's your problem.
What I was *most* concerned with is driveshaft critical speed per what was in post #7 (IJ's comments). If you don't want to make a 2 piece shaft, that's fine. You asked, so I put in my 2 cents ;)
shaftmasters
Vendor
Oct 29, 2007
95
michigan
Hi jdub,
We have no problem working on a two-piece design for you guys. Give us alittle time and we'll see what we can develope for you. Off hand, I was wondering if you would consider just replacing the rear shaft with a new aluminum shaft with solid 1310 series performance u-joints complete with new flanges that would bolt right up to your existing front shaft.By going with a lightweight aluminum shaft it could run well with the original front shaft without requiring to balance the two as a set. What are your thoughts on this. I also wanted to add that I am sorry if I came off short with you but I take my business seriously and started to feel like some members thought that we were trying to force a unsafe product on you, which is not the case. Shaftmasters would never suggest or sell a shaft that would create anymore liability than the factory original. Our one-piece shaft falls well within Dana Corp. Guidelines for a single-piece shaft the length of the Supra's.
Robert
shaftmasters
Vendor
Oct 29, 2007
95
michigan
IJ. said:
Spicer make a 1350 slip yoke to suit the 340/154 that makes the front easy.
Thanks it is good to know that they also make them in 1350 series along with the 1310 series that we already have in stock. The transmission yoke for us is not the hard part. It is the hanger bearing stub. As of now we don't know of a source other than a Toyota dealer to order a stub which is only available as part of a complete shaft. We would have to order a complete shaft in order to just retreive the stub off of it.
Robert
Tun_x
Built to do the NASTY!!
Utah
I just wanted to chime in and say thanks for taking the time to find whats needed and wanted in the community ...
Jason
