my lil brother damaged my oil pan? how bad is it?
queenskid926
Tires yeling @ every Lite
Jul 27, 2007
1,112
New York City
i went to work he wanted to work on the supra and he knows a few things about working on cars from hanging around me a lil bit. i told him if he could place the motor on the motor mounts before i come home ill give him $50. well the lil knucklehead did it but said he jacked up the oil pan to lift the motor to do it. Immediately i ran outside to take a look and this is how it looks.
i just got the motor in and evrything bolted. Will this affect the oil pump pickup? is it that bad? should i even start the car?. Can i get away and drive like this? im werkin on the car now and should be finish 2nite and wanted to start her up now she has boost.
MKIIINA
Destroyer of Turbos
Plano, TX
doesnt look too bad but replace it. an ounce of preperation beats the pound of pain you will pay later to swap the pan.
+1 on beating him with the timing belt
queenskid926
Jul 27, 2007
1,112
New York City
haha yall you guys are funny but yea he knows how mad i am rite now at him, yes i plan on replacing it but is it safe to start up and drive to werk? ill keep my eye on the oil pressure
queenskid926
Jul 27, 2007
1,112
New York City
well we all know how bad the stock 7m oiling is. im just afraid that the oil pan is bent up right where the oil pump pickup is which will result in low or no oil pressure,. if i started it and run and drive and oil pressure is good then everything is good rite?
a_sesshoumaru;1048760 said:
i think it wont make any difference, but keep asking, i dont want to be blamed
drbowser3
The Doc is in...
Jan 17, 2006
215
Tampa,FL
I would not start my car like that. Unless you bolted everything and plugged in everything, in reality, how long would it take to pull the motor back out. I personally can pull the motor from everything plugged in and running to out in about 30-45 minutes.(With help from 1 person)
queenskid926
Jul 27, 2007
1,112
New York City
two of the wheels on t he engine lift that i bout to do the swap broke and i returning it yesterday and instead of gettin another one i just got a full refund cause i figured i woulkdnt need it anymore no time soon. and everything is 99.9% bolted in for it too start. only thing left is to plug in the battery and do the power lines for the started, a few grounds, sparkplugs wires and add fluids thats it. im actually at the point that i dont even wanna pull the motor again, ive put so many hrs into this that ill just pay my local shop to swap oil pans.
Jaguar_5
It's ALIVE!
Feb 7, 2006
1,468
Seattle
Do like the redneck rodnock fix, support the engine with some 2x4's accross the shock mounts with a chain, remove the subframe, and replace the pan
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
I seriously HATE crawling around under a car and working from my back. I would pull the motor long before I would drop the subframe to replace the pan. From my memory the stock oil pickup is pretty close to the bottom of the pan, BUT Ive seen pans mangled worse than that and not cause oil starvation.
Cletusmod alternative if you have a welder: Being careful not to push shavings up into the pan, drill a hole in the center of the pushed up section. Using a slide hammer and screw in tip, pop the dent back out like you were doing body repair. Then once its pulled back out sufficiently, just weld up the hole. I would think that could be done in a couple hours.
queenskid926
Jul 27, 2007
1,112
New York City
thanks man ur givin me hope, i have basically everything ready now just add fluid and the starter and battery. i think if the oil pressure is good then it shouldnt be a problem rite? ill find out soon guys
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I'm not sure how likely this is though... but it's worth asking.
How much clearance is there between the baffles and the oil pickup? If there's any chance the pickup got hit the pipe could have been creased creating a restriction you may not see until at higher loads.
HommerSimpson
1,067
New Smyrna Beach Florida
IMHO............. it fine... the pick up screen on these is so huge and wideopen if you smashed it down to 1/2 from tube it will still have 1/2 x 6 inch of screen still open to oil around the edge of pick up...If you know what the screen looks like.. you might get my drift.. if not find a pic
Now this is just my opinun... :}
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
CRE, That is seriously unlikey since the damage was done in a no jarring way, meaning it was just pushed up from the weight of the motor and not struck at speed from below. The oil pickup pipe is pretty tough and I think its FAR more likely it would just get pushed over a little rather than crease.
If it were me doing it. I would take the EFI fuse out and crank until it had pressure (as you should do anyway after the motor has been out/apart). If you get pressure under cranking, it should be fine.
This is a stock motor right? nothing ultra high performance?
queenskid926
Jul 27, 2007
1,112
New York City
ported polish 3 angle valve job on the head, and 1.2mm hks mhg with arp bolts. thats it.
johnbot123
supra noob
Jun 22, 2007
queens, ny
pull the emgine....the time is not worth the money of a rebuild IMO. i crushed my oil pan the same nite i put my engine in as well......i had to pull the engine and was pissed, but i slept better that night knowing i was on the safe side. listen to IJ, he knows what he's talking about.
