Main Bearing Question
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
i heard people replace just bearings after having knock, as long as the car wasnt run very much after the knock started im sure it could last a few months easy if not a lot more. Ive seen people do it in other cars, dont know about the 7mge. Its worth a shot, id rather try it than sit around and not try it.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Yep, the first day I heard the knock, I baby'd it home and turned it off immediately. It was barely starting to knock. The knock was very faint; but, I was pretty sure I knew what it was.
I finished replacing all the rod bearings tonight. The one that was knocking wasn't all that bad. It was bad enough to knock though!:naughty:
The mains looked good so I'm putting her back together and will fire her up this weekend. Barring any unforseens.
Then...the second engine is off to the machine shop. It won't be long now!!!:biglaugh:
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Pat did this to my car before I got it. Runs fine, no knock whatsoever at 15PSI on a 62-1 daily. He said he tried it up to 18PSI on the dyno and it was still going strong. However, he also shut it down the second it started, and you said you didn't. Either way, being a Toyota, it might run knocking for a good while. I spun a bearing in my Celica, possibly broke a rod, still starts up and runs and drives (20W50 in winter... Sometimes it takes a while to start lol)
If you just need it to last a week or two, what you're doing could work. If you'd have parked it immediately, the odds would be more in your favor.
EDIT: Here's his writeup for it. http://www.supramania.com/forums/showthread.php?t=39754
CajunKenny
Nov 15, 2007
3,255
Washington
Yeah, I'm hoping it'll last a little while.
This thread got enough attention that I'll post my findings.
Judging from the condition of the bearings, my guess would be that it should be fine for a good while. Some folks feel differently. I guess we'll see though.
:icon_bigg
Doward
4,245
Alachua, FL
No, it will last for a little while.
I just don't understand the mindset of spending the money (however small) and time on it.
If I had a 2nd engine to go in, I'd just bump up the timeframe on it. I hate spending money twice, you know?
KMinAF
Old Man
Sep 15, 2006
291
American Fork, UT
For the $40.00 a set of bearings cost put them in and have fun.
Yes you can rotate the mains around the crank but it isn't easy and in your case not worth it. Keep in mind that a rod knock does have adverse effects on the rod journal, often elongating them so that they aren't round any more.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Actually, I did this. Then when the second engine was ready, I turned up the boost on the first setup until it blew up. I wanted to know just how "terribly unreliable" the stock headgasket really was. The answer is, it's not very unreliable.
For those of who don't mind pulling an engine, it's not a big deal. I've done it often enough that I can pull one out and put the other one in on a weekend if a couple buddies help with the heavy bits.
CajunKenny
Nov 15, 2007
3,255
Washington
Man, as negative as people are, you'd think I was spending their money and doing this to their car. :icon_bigg
Update: The pan and block are all clean and ready for 'goop' and re-assembly. This will be done tomorrow after work. I'll replace all applicable fluids and fire her up Saturday, maybe Sunday.
Unless something unforseen happens of course...like I forget to get my sockets and ratchet out of the pan before I bolt it back up! :naughty:
Thanks for all your input. Yessssss even the folks who think it's going to blow up as soon as I turn the key! :biglaugh:
CajunKenny
Nov 15, 2007
3,255
Washington
Ok. Here's the update.
My friend and I got everything put back together today, primed the oil system, and then let her rip!
Crank...crank...crank...crank... And more crank...crank...crank...crank...
Cracked the FPR fitting and nothing! No fuel pressure! The car has been sitting in my garage for approximately 2-1/2 years.
The consensus is that the fuel pump has died. I don't know. Maybe the old/bad gas killed it.
Anyway...Walbro will be ordered and maybe some 550's!!
CajunKenny
Nov 15, 2007
3,255
Washington
GrimJack;890950 said:
Erm... does it have any gas in the tank?
LOL... Yeah, right after I drained the tank of the old stinky bad gas, I put 5 gallons of new in.
Good question though! :naughty:
