Key falling out... HELP!!!!!
LilMissMkIII
That Aussie Chick
Aug 18, 2006
4,110
Aussie Land
Hey guys,
As stated in the thread title, my key falls out WHILST THE CAR IS RUNNING...
Any ideas on why this is, and what we can do to fix it?
Cheers,
-K-
Clied
Wangan Supra
Jun 8, 2006
367
NorCal
Mines like this too, I can take the key out of the ignition while im driving and my motor wont shut off. Just get a new key.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I'm suggesting a little bit of CK's advice and IJ's advice.
All seriousness, wouldn't that mean the tumblers are getting too worn?
mkIIIman089
Ohio
IJ. said:
Take the 10kg's of girlie crap off the ring? ;)
You know, I was wondering how something on a downward angle "falls" up. LMAO.
I would start with a new key... if that doesn't do it, looks like you might need a new cylinder.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
More often than not it's the wafers. If your locks are worn to this point I would recommend you rebuild the locks and get new code cut keys.
supraman7mgte
Shut up,bitch!!
Sunny California
sounds like the tumblers are getting worn on the ignition. a new key might remedy the problem. hopefuly you don't have more than 4 keys on the Supra key ring,thats what makes them wear out so fast.
johnathan1
Supra =
Aug 19, 2005
5,056
Mine did this, and I think it was caused by the cheap "Ilco" key that someone had cut for it in the past...it was much thinner than the original Toyota key, and I'm betting that it wore out a LOT faster.
Get a new key cut from the dealer...the new key blank cost me about $20, and the actual cutting was free... My key doesn't fall out or anything.
CRE
Oct 24, 2005
3,485
Denver, CO
The biggest factors to wafers wearing down very quickly is how fast you insert or remove the keys. Making sure the cylinder is well lubed with some graphite will help. So quit banging your ignition like it's prom night and do like you b/f, g/f and/or spouse prefers and use some lube.
jetjock
creepy-ass cracka
9,439
What CRE said. Fwiw every case I've seen of this a new key fixed it but it could be too late for some locks. Same with all the other little stuff that gets ignored. Door, hatch, and hood hinges, latches, power seat, steering column, ect. You have to be anal if you want things to last.
bmoss85
Permanently Banned Scammer
Apr 14, 2007
1,026
clemmons, nc
yea my key can come out as well, bought a new and it did the same thing, i also have like ten keys on the same key ring.
depends on the year as well...
pre-89's have s different key and tumbler design (same design as my 82 truck that had the keys fall out all the time)
my 89 doesn't have this issue...
It's pretty common on old toyotas...
If you can get it, buy a new lock set or see if they can rebuild your locks...
CRE
Oct 24, 2005
3,485
Denver, CO
The remaining possibility if they were new all new is the key's cut order and the condition of cylinder housing.
LilMissMkIII
That Aussie Chick
Aug 18, 2006
4,110
Aussie Land
Such a pita GRRRRRRR
Oh, and those of you jumping on the "she's-female-so-she-has-a-shitload-of crap-on-her-keys" bandwagon can go and jump... I have only 2 x car keys and 2 x house keys, THAT IS IT!!! The bf has more that double the weight on his than what i have on mine, so ner ner ner! :icon_razz :icon_razz :icon_razz
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
my car was broken into at one point before i bought it, so the cylinder's fucked up, and i can take the key out while driving, and if i accelerate quick enough, it'll fall out..
sucks, but kinda funny..
