just joined the 1uz club
4U2QUIK
1UZFE SWAP DUDE!!!
Here's some usefull information for wiring this engine up.
I'll start with the supras plugs for today
First Off is the "M1 Plug" Here is what it looks like.
Pin1, Red with Black Stripe - Reverse Light
Pin2, Yellow - Reverse Light
Pin3, Pink - Speed Sensor
Pin4, Black - Tach Signal
Pin5, Empty
Pin6, Brown - Water Temp Negative?
Pin7, Yellow With Black Stripe - Oil Pressur Signal
Pin8, Grey With Green Stripe - ?????????????
Pin9, Yellow with Blue Stripe - Water Temp Signal
Pin10, Purple - ?????????????
Next Is The B1 Connector
Pin1, Black W/Yellow Stripe - Cruise Clutch SW.
Pin2, Red W/White Stripe - To Tems FromTCCS
Pin3, Red - To Tems FromTCCS
Pin4, Black - To Tems FromTCCS
Pin5, Black w/Red Stripe -Fpump Check Wire
Pin6, Green -Circuit Opening Relay
Pin7, Yellow -Fpump Relay Controll
Pin8, Black W/Red Stripe -EFI Main Relay Hotwire
Pin9, Blank
Pin10, Light Green W/Red Stripe -AC Water Temp Switch
Pin11, Lavender W/Blue Stripe -From AC amplifier
Pin12, Purple -TS on check connector
Pin13, Blank
Pin14, Grey -Ignition Switch
Pin15, Blank
Pin16, Yellow W/Blue Stripe -????????????????
Pin17, Black W/Blue Stripe (Heavy Guage) -To starter Solenoid!!!!!!!!!!!!!
Pin18, Black W/White Stripe(Heavy Guage) -ST1
Pin19, Black W/Orange Stripe(Heavy Guage) -IG2
Pin20, Blank
Pin21, Blank
Pin22, Red w/yellow stripe From Headlamp Relay????????
4U2QUIK
1UZFE SWAP DUDE!!!
Plug B2 is almost Useless considering it's used almost completely by the automatic transmission wires.
But I'll post it up anyway!
Pin1, ECT Solenoid Ground
Pin2, Red W/green Stripe - ECT To Transmission
Pin3, Green W/Yellow Stripe - ECT To Transmission
Pin4, Blank
Pin5, White - AT indicator Switch to ECT Computer
Pin6, Light Green W/Red Stripe - ???????????????????????????????
Pin7, Blue - AT indicator Switch to ECT Computer
Pin8, Green - AT indicator Switch to ECT Computer
Pin9, Red w/Black Stripe - ECT To Transmission
Pin10, Red w/blue - OD Signal Wire
Pin11, Blank
Pin12, Blank
Pin 13, Yellow W/Blue Stripe - TPS Idle Signal
Pin14, Yellow W/Black Stripe - T1 on Chack Connector
Next Plug Is B3. This is a good plug to know if you want to get the abs and pps working.
If you have your 7mgte harness ready for the sacrifice you can pull this plug and the plugs on the other end with only cutting 1 wire. Now your pps, and abs are plug and play!!!
Pin1, Black - ABS Sensor RR Positive
Pin2, Red W/Black or blue? Stripe - ABS Sensor PSEN
Pin3, Blank
Pin4, White w/Red Stripe -PPS Solenoid Positive
Pin5, Yellow -ABS Sensor RR Negative
Pin6, Lavender w/yellow -ABS Sensor ECT
Pin7, Blank cut this wire! it's useless for the swap
Pin8, Blank
Pin9, White ,/Green Stripe -PPS Solenoid Negative
I'll post up the 1uzplugs later
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
4U2QUIK;1515618 said:
ahhh gotcha. I thought you got the other one. I was kind of interested in getting that shell that I passed on. I keep on kicking myself for not buying it. It was only 300$ and I had plenty of cash at the time.
i might by that na supra soon its 89 a dent in front of the right rear tire though i just want the interior....are you almost done with your 1uz sup..?
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
4U2QUIK;1531954 said:
almost, I'm going to get the driveshaft somtime this week, and I'm about to buy my exaust right now.
yea what kind of exhaust...? so what by the end of this weekend you think itll be up and runing....? im down to come threw and check it out...have you got a seat yet..?
ihiryu
209
TX
I got most of my stuff already ;)
Got a w58, and will be buying the DS tomorrow, did you ever find out what Howe TOB to use yet??
ihiryu
209
TX
4U2QUIK;1535947 said:
I already knew which one, I just didn't have the part number even remotely near me when you asked.
#82870 THERE'S 2 VERSIONS! one is a race version and the other is a compact version. Summit sells the race version which is what I'm using.
Lol my bad I'm sorry! You are the mannnnnn! I promise I'll be putting in an order soon! Just gotta secure this D/S, shifter, and trans mount then I'll have everything but the clutch and harness to put it in, I'm so psyched!
