JT2MA71's Build. Dyno video on post # 1191
jt2ma71
Impeller Head
Washington State
Thanks. Here's what I did this weekend, not much. I still need to cut the brackets out (3/16" SS) but you guys should know what I'm making here, right?
Tire Shredder
569
Oshawa
I am not a fan of solid mounts either. what is your main goal with it? are you trying to prevent the motor from ripping the engine mounts/the prevent turbo from contacting the shock tower? (this is an issue with high power turbo mk2s with large turbos on a stock manifold.
jt2ma71
Impeller Head
Washington State
Exactly, just like an additional mount.
Ron: I use the pre89 square mounts as they have limiters and I still bolt the Toyota Torque limiter/damper shock to the left mount.
Both my mounts were original 86 parts and were 90% broken through age but still held the motor in place.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
i don't think it is possl;eb ian to use the 7m montes on a 1j block with out some3 fabing wqhen you chould just fab hole new one
mabey look up enrgey suptionj and look what take littel work to make work
